Question about Kitchen Ranges
Maytag gas oven won't light - Kitchen Ranges
  • mwettlaufer May 27, 2008
    The problem has turned out to be the "glow plug" that is used to ignite the oven (electric start). It was heating up, but not enough to release the gas valve.
    I thought it was ok because it would get very hot (orange) but the technician noticed a burnt spot on it and immediately suspected it wasn't getting to the 3.5Amps necessary to release the valve.
    Replaced the igniter and all ok.
  • Anonymous Jun 13, 2008
    When I turned knob to turn on oven, gas escaped but no flame or heat. Is it always the igniter?
  • 13 Answers
After moving my oven out of the room to lay a floor, the oven wouldn't work when I put it back. Everything else worked (top burners, broiler).
I spent much time here and elsewhere on line trying to get enough knowledge to at least diagnose the problem, if not fix it. There is nothing worse than not knowing what is wrong when the repair guy comes, because you are then at their mercy, and some of them are less than merciful!
I took it apart, observed how the broiler worked, and assumed logically that the oven should work similarly.
The igniter on the bottom/oven part seemed slightly further away from the gas tube than the broiler igniter did. I just touched it and it moved!
As it turned out, the bracket that holds it in place had become jarred when I moved it, and had moved almost imperceptibly away from the gas tube.
This tiny difference was enough that the ignition didn't take place. Instead, after 4 clicks, the igniter shut off, a safety issue built into it, I suppose.
I attached the igniter to the gas tube with wire, readjusted and tightened the clamp, and Bob's your uncle, i have my oven back!
So, I guess the 'tip" is to simply make sure the igniter is close enough to the gas tube to actually ignite the gas.
As any repairman will tell you, the order to check things out in should always start with the simplest thing first!
Posted on Sep 04, 2008
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
MGR5729ADH Ignitor gets hot. Gas won't come on
The problem with the oven not lighting believe it or not is going to be that the igniter is weak and not drawing the correct amount of power to allow the gas to flow.I know it would seem since the igniter comes on that it could not be the problem yet since it comes on to me a oven technician with 30 years experience the igniter is exactly what it is.
GENE
Sep 24, 2011 | Maytag Ovens
Maytag oven model mgr5770 oven hard to light and doesnt keep temp even when it does gas stops lighter still glows?
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps
Gene
Aug 01, 2011 | Maytag Kitchen Ranges
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Bottom burner for maytag gas oven will not light. The broiler will turn on and heat, but not the bottom burner.
will have to replace the oven ignitor part #120000035 / this will correct burner problem / mm
Dec 08, 2009 | Ovens
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
2,677 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
