How can i easily partition my hard drive in vista? i want to set 2 partitions one thats 12 gb and one thats the rest of my hard drive.
  • 19,396 Answers
Use one of the following free software packages.
Backup all your data before partitioning, as the hard disk may need reformatting (and reinstalling Windows) after partitioning.
CompuApps SwissKnife
Cute Partition Manager
Super Fdisk
Posted on May 26, 2008
HOW TO SET ORIGINAL SIZE OF HDD SEGATE BARRACUDA ST380011A THAT I WAS SET TO LIMITED SIZE I.E. 32GB NOW I WANT SET IT TO 80GB WHICH IS ORIGINAL SIZE.
Purchase or download a partition manager program.
The only way you can easily manage or change your partition size is to get a third-party program.
Partition Magic Freeware is the most widely known partition manager software. http://www.filehoo.com/download/Partition-Magic-8,0.aspx You can also download freeware programs such as Cute Partition Manager. http://download.cnet.com/cute-partition-manager/3000-2094_4-10605516.html
Open or run the partition manager.
In Partition Magic you can open the program easily. In Cute Partition Manager you may have to create a boot disk and boot from it to run the program. Once the program is open, select the drive you want to manage.
Go to the menu and choose an action or right-click and choose "resize." There will be an action -menu that will let you choose something like "resize" or "change hard drive size."
Some programs will also let you right-click on the graphical expression of a drive and choose the action or drag the graph to change the size.
Pick a new size for the drive and decide what you want to do with the remaining space. The rest of the space should be partitioned or formatted to make use of it if the current partition is downsized.
Apply the changes by clicking "apply" or "OK." You will then have to reboot the computer for the changes to take effect. The program may automatically do this for you or it simply may direct you to do it.
Aug 24, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Tip
How to properly setup a single hard drive for Windows.
Hello Windows user, setting up Windows on your hard drive is easy, but there is a better way to setup Windows so you will never have problems later, (especially XP users), So before you start setting up Windows, I suggest you partition your hard drive to 2 (or 3) partition, one for the system (usually this is drive C:), one for your data (this is drive D:). Partitioning simply divides your hard drive to several sections, the main advantage is in case your windows system goes bad, or get infected by a virus, you can easily back up your important documents, simply copy all your important files to drive D: (drive D: is not erased if you setup Windows on drive C:)
for example:
To create a partition, on an XP setup, using a 160GB hard drive, divide your 160GB Hard Drive to 2, Press C to create a partition see picture. 80GB for windows system files and 80GB for data files.
Never setup the entire Windows on drive C: alone. create 2 partition. So before you choose where to setup Windows, there is an option to create another partition, input how much storage space you need for the partition in our example 80GB on a 160 GB drive. then proceed to setup Windows on drive C:. (at this point there are two drives, C: and D:)
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
On Windows Vista, although the backup is automatic, its much wiser to partion your hard drive.
on Apr 07, 2010 | Computers & Internet
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
Unble to formate the pendrive
Free Partition Software - MiniTool Partition Wizard Home Edition home1.png MiniTool Partition Wizard Home Edition is a free partition manager software designed by MT Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista and Windows 7. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions, Copying partitions, Create partition, Delete partition, Format partition, Convert partition, Explore partition, Hide partition, Change drive letter, Set active partition, Partition Recovery.
Dec 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to make partation in new hard disc using window xp
Hello sir and Windows user, setting up Windows on your hard drive is easy, but there is a better way to setup Windows so you will never have problems later, like back up and searching for flash drives (especially XP users), So before you start setting up Windows, I suggest you partition your hard drive to 2 (or 3) partition, one for the system (usually this is drive C:), one for your data (this is drive D:). Partitioning simply divides your hard drive to several sections, the main advantage is in case your windows system goes bad, or get infected by a virus, you can easily back up your important documents, simply copy all your important files to drive D: (drive D: is not erased if you setup Windows on drive C:)
for example:
On Windows Vista, the backup is automatic, but then again, its much wiser to partition your hard drive.
Sep 10, 2010 | Maxtor Hard Drive
I want to extend c(primary partition).. without losting data..
i have a 80 gb hard drive in my compuetr & after somtimes it shows error less space i c: drive. and d: is totaly free now i just want to make my d: drive as c:. or i want that my data automatically transfer into d:. in other word i want to make my d: as a c: without delete partition.
May 18, 2009 | 01 Communique Communicate! I2000 Full...
MY 10 GIG HARD DRIVE IS FUNCTIONING AS A 2 GIG HARD DRIVE, ITS ONLY DISPLAYING ABOUT 2 GIG AND THATS ALL IM WORKING ON, I RECENTLY INSTALLED XP ON IT. WHERE IS THE REST OF THE SPACE? THERE IS ONLY ONE...
Since it is an old drive. It could just been formatted on 2 gig where FAT system that can run using windows OS. Just partition the rest that is remaining, activate it and then format it to make it usable. You can use third party partitioning software if you like. And before I forgot check also its jumper if setting is lock to access on 2 gig only.
Just for input.
Regards
Apr 08, 2009 | IBM (10K2059) 10 GB Hard Drive
Rules for runing partitiom magic
The FixYa Team
Thanks for the respone
I have been informed by the VISTAHEAD admin. that vista can not be partitioned by more than 4 parts.
I used the shrink function available in the Vista computer manger , rename the DVD drive label, and labeling the new partitions, then format them as NTFS, then reboot twise for taking the configuration setup and every thing is o.K. without the need for the partition magic.
Now i have only 4 patitions. But didn't know why is this limit?
Beside that i read that the partition magic v8.0 cannt partiton the vista O.S main drive.
Thanks
Abo_Anas
Feb 02, 2009 | Western Digital (WD3200JS) 320 GB Hard...
How to install windows xp on new Acer Aspire L320 computer
you can set the partitions in f-disk on the start up disk of windows 98, reset partitions to 32, format c: drive, take out disk and put in windows 98 cd. and restart computer. your done. windows 98 cd will install. your up and running. please give me a fixya rateing. Thanks farren
Dec 20, 2007 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
