Question about GE Profile Spacemaker II PEM31 Microwave Oven
When I enter the cooking time (2 minutes, 30 seconds for example) then push the start button, nothing happens. The start button doesn't click or have any resistance so I suspect it is defective since the clock is operating, even after I push the start button. Any ideas?
  • GE Master
  • 9,085 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on Oct 02, 2010
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
How do I change temp and time while food is cooking?
all is explained in the user manual
if you have just put food in the even and pressed the start several times to get a number of minutes to cook but want to increase that time just press start again the number of times that you want the cook time to increase
for example :-
you put a frozen pie in the oven and your start operates in 30 second increments and you have pushed it 3 times and it starts cooking-BUT - you read the cooking instructions and it says cook for 4 minutes, just press the start another 3 times while it is cooking
the new cook time will show on the display
Dec 30, 2016 | Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
How do I enter a time of less than 1 minute? Bought a brand new Oster Microwave model OGZJ1104. I cannot figure out how to heat up a cup of coffee for example - for 30 seconds. The user manual has
Usually a quick start button along with dial to scroll down from one minute.check if any buttons are push click to see if they extend away from fascia once pressed or try select one minute then use main dial anti clockwise to reduce time.hope this helps.
Feb 01, 2015 | Oster Microwave Ovens
Ge spacemaker xl jvm1340
CHECK THE MAGNETRON SIDE OR HIGH VOLTAGE SECTION PROBLEM
Jan 09, 2014 | Microwave Ovens
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
GE Profile Spacemaker II PEM31 Microwave Oven Logo
145 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
