Question about Euro-Pro 373 Mechanical Sewing Machine
I have an Omega model 377/374/373/372/373om. The top thread thread does not catch the bottom resulting in no stitch. Also there is a plastic screw on top which has =/- on it which appears nowhere in the manual. Thanks
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
SOURCE: Yet another stitch tension problem...
Thank you, thank you! I just tightened the screw on my bobbin case and that instantly fixed my thread tension problem. How on earth are you supposed to know about the little screw?! I thank you so much for the tip!
Posted on Dec 14, 2007
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
  • 192 Answers
SOURCE: Machine is skipping stitches
One of the things that can cause this is lint buildup around the back of the hook driver. Open the bobbin cover and look just above the hinge, at the bottom edge of the black hook cover. If lint is peeking out at you, it may be time to have it serviced. You may be able to get most of the lint out if you remove the needle plate and blow onto the back side of the hook area with canned air. Keep the cover open so the lint can come out.
Now I am assuming that you have replaced the needle.
Posted on Oct 23, 2008
  • 749 Answers
SOURCE: won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Posted on Nov 01, 2008
Sewing outdoor polyester ( denier) medium weight with outdoor polyester thread. bottom stitch is not straight? evenly spaced but irregular in alignment. Help?
increase the needle thread tension
the bottom stitch is a direct result of the needle movement pulling the bobbin thread up to the hole so for the bottom stitch to be irregular , so is the top stitch
Nov 22, 2015 | Sewing Machines
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
My brother computerized sewing machine does not catche the bottom thread to make a stitch
try using a longer needle, or lowering the one you have now by loosening the needle screw and dropping the needle down some
Aug 08, 2014 | Brother Sewing Machines
Why does fabric get caugh on the roll hem devise when over locking
this sounds like an overlocker/serger machine you are using? if the fabric is catching on the overlocking tongue it could be a number of factors, have you lifted the top cutting blade out of the way and forgot to put it back into place? That would be my first thought, the top and bottom blade move against each other cutting the fabric. Rolled hemming usually requires the blade to be set on about 2, or middle of its setting range, the stitch finger is pulled back out of the stitching area, top looper thread is loosened off and bottom looper thread is tightened up, resulting in the top looper thread wrapping around the edge of the fabric and pulling the cut edge down under within the seam, forming the rolled hem.
May 13, 2014 | Elna Sewing Machines
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
I had my machine in the closet for 5 years and now need to sew a hem on my cotton pants. What should the settings be set at? Right now it is at a 4 and the stitch length is a 2 1/2. The thread is too...
If your machine has been stored for 5 years, you should give it a good clean and oil according to the manual before you do anything else. Then put in a new needle and wind a fresh bobbin, checking that the bobbin has been wound smoothly as a badly wound bobbin can cause poor tension and stitching from the bottom thread.
You want the thread to go from the spool through a tension disc or eyelet to the bobbin and keep some gentle tension onto the thread spool using your scissors handle or similar so that the thread winds off it smoothly and the spool doesn't bounce around. Also give the thread a nudge with your finger tip as it winds onto the bobbin so it fills evenly, top, middle and bottom, not all in the middle.
Are you wanting a straight stitch to sew around the hemline? If so, your stitch length is right, but stitch width should be zero. You don't say what knob is set to 4, if its your top tension then that should be close, usually between 4 and 6 if dial goes from zero to 10.
Which thread is too tight? top or bottom. Firstly check the threading path to ensure that the top thread isn't catching on anything, is through the take up lever properly and coming from the thread spool without catching there. Some thread spools have a little knick in the top where you can catch the thread to store it, but you dont' want the thread to catch here when seaming, so turn it around the other way on the spool so it can't.
Try test stitching a medium zig zag stitch on scrap fabric, and you'll be able to see if the bottom thread is pulling in or the top one, then adjust the tension dial a little to lessen this.
Hope these pointers help, if you can't get a good neat stitch after trying these things, then consider taking it for a clean and service, the technician can get inside and clean the machine thoroughly and also check for any other issues that might be there.
Apr 30, 2011 | Singer 57815 Mechanical Sewing Machine
Every 4 or 5 stitches the bobbin thread fails to catch the top thread resulting in skipped stitches
double check needle position and needle type. It will also do this on stretchy material, do to material catching on the thread
Aug 30, 2010 | Janome 1017 Mechanical Sewing Machine
Top thread won't create a stitch
Hi! Check that you installed the new needle correctly. There is a flat side on the needle shank and that has to be facing the rear (away from you) on this machine in order for the top thread to catch the bobbin thread and make a stitch.
Let me know if this works, ok?
Robbie
May 11, 2010 | Kenmore Sewing Machines
The thread bunches at the bottom. It worked fine then one day in the middle of my sewing it bunched. I rethreaded. I adjusted bobbin tensions with the little screw and on top. Help
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Jan 31, 2009 | Singer 3116 Simple
Euro-Pro 373 Mechanical Sewing Machine Logo
410 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
