Question about Emerson Audio Players & Recorders
I have an es8 emerson and the door on top to the cd player wont open
I just fixed this not to long ago. Take off the left side panel and replace the black belt with a rubber band of about the same size.
Over time, these small belts become stretched and lose their grip on the pully.
Posted on Nov 24, 2010
My has a weird problem... 1st turn normally to clockwise after stopped go counterclockwise and doesn't play the only way to play it.. its if I force to go clockwise. help pls
Posted on Apr 06, 2011
Cd's wont play
Some common things to try:1. Make sure its a CD-R and not a CD-RW.
2. Try burning at a slower speed like 4x.
3. Try a different brand of media, some players are picky.
And finally you may find that your car CD player just wont play CD-R's. So you may have to give up or replace the system.
Aug 21, 2013 | Emerson MS3100 3-Disc CD Changer
My cd player door opens then close then stays open
The disc loading mechanism is faulty. Check the loading belt first. Replace it. If this do not help you, replace the disc loading mechanism. if you are not handy, seek tech support.
Jun 04, 2012 | Emerson MS3100 3-Disc CD Changer
The DVD tray will not open on Sylvania SRD4900 dvd/cd/vcr player. How can I get it to open?
Press the eject button on the DVD player. When you hear it try to open, tap the player gently but firmly on the top by the tray door. It may take a few tries to get the timing down and just how firm you need to tap it.
Dec 01, 2009 | Emerson MP530 MP3 Player
My emerson tv/dvd player wont work.
need reader pcboard that set ontop of dvd it a chip that till the drifent from dvd to cd
Jun 02, 2009 | Emerson EWC20D3 20 in. TV/DVD Combo
Emerson AV50 says ''NO DISK''
Hi, sounds like you have a dirty laser eye on the DVD player. The eye gets dirty and it won't read movies or function properly. I would recommend a DVD Cleaner CD. I would have you try this before I have you open the DVD Player to clean the Laser Manually. Please try this and Post the Result for me to Review. Thank you
May 19, 2009 | Emerson Audio Players & Recorders
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
The rubbing Emerson CD player
hello, is this a carosel type loader? they have other internal parts that rotate it for selecting cd,s i understand what you mean.
the reason i say to open the case is incase there is something obstruction the mechanism from going in to the right return position
if you allready checked for this and theres nothing blocking the return cd holding part. then you may need to check this cage assembly for internal broken loose screws or jammed parts.
some plastic parts sometimes break or wear out and cuase the return cage to not load the cds properly. this is a loader issue
your on the right track, it is something with the returning cage
also at times the rubber shock resistant booties on the cd reader & motor assembly they are missaligned or come apart
if a cd dosent sit properly it pushes the drive motor and thats when the rubber mountings can come apart. reader assembly & motor mounts. check for this also.
good luck with your player.
happy holidays
Dec 19, 2008 | Emerson MS3108 Shelf System
CD door
try cleaning the mode swith that opereates the dorrs it sounds like its dirty
Nov 15, 2006 | Emerson MS3100 3-Disc CD Changer
292 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
