Question about RCA Televison & Video
Somehow pushed the wrong button on the remote ( rca r401a1) and trying to get digital cable to work....when hitting the input button to get the picture to come up....cvid,vid, frnt,svid..then i think is where the problem is...it should say )i think chp or chmp1) and it has some numbers...when it is on vid and cvid i can hear the channel my digital cable box is set up to....all i want it to have my TV programmed so i can watch it
  • 30 Answers
SOURCE: Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Posted on Jul 17, 2007
SOURCE: no channels
I have the same problem... IT WAS WORKING FINE WITH BASIC CABLE PLUGGED RIGHT INTO IT, POWER WENT OUT AND NOW I GET "NO CHANNELS IN LIST" AND NO WAY TO ADD CHANNELS!
I am very techy person, and have tried EVERYTHING you can possibly do... believe me. A simple scan results in "signal not detected" error. NOTHING was moved, only the power went out?! WTF!
We've got this at work (BLACK Olevia 36 Inch I believe).
Please email us @ kggc00@bellsouth.net THANKS!
Posted on Jan 08, 2008
SOURCE: TV not finding Digital Channels from Cable Box
I just bought Sony LCD 46 inches, with model KDL 46 V 2500 about less than 9 months,now TV lost digital channels, I tried every thing to program it but it's not working, when I program it the screen come up and stay about 20 minutes for searching digital channels then disappeared.and always no digital found.I don't know what wrong?
Posted on Feb 07, 2008
  • 86 Answers
SOURCE: tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Posted on Feb 24, 2008
SOURCE: RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Posted on Mar 24, 2008
Wheni push input, i get the options but no arrow i push will move down to option to play vhs
not enough info , if your trying to change the tv input , make sure you select tv on the universal remote first , you either need to keep pushing input til it moves down to your desired input , or use the arrow key to move it down to the input. some require you to hit enter or ok to select , others just wait a second , it should change. if your getting the options menu when your hitting input , then the remote is not compatible with your TV / VHS / DVD...
If you get the input to change and your successful , make sure you hit VHS in order to call a command , if its still in tv mode , your only going backwards , make sure whatever your trying to control , the remote is selected to that device ... Good Luck ..
The Cable Guy .... hope that helps !!!
Mar 12, 2015 | RCA RCR314WR Universal Remote Control For...
I need to know how to program this tv so that the cable will come in. It used to work but unknown buttons were pushed on the remote and now the cable will not work on this tv.
Somebody probably hit one of the input buttons and changed the input. Try hitting input and going through the different options. Give each one a few seconds and see if the cable comes back on.
Oct 18, 2012 | Televison & Video
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
I have a RCA Truflat tv model 20F420T and serial number H494E2526 and accidentally hit a button on my digital cable box remote which sent the tv into a mode showing FRNT. In trying to solve the issue, the...
Using the remote control hand unit that came with the TV turn on TV. Then go to the set up menu. Locate the entry for Front Panel Lock (FPL) and select no. Once you have done that exit the set up menu then on the same remote push the "input" button while watching the screen. Push button once wait a few seconds for a picture to appear, if not then push the button again, continue until you have selected the input that provides a picture. Right now you are in the Front inputs you should look for Video 1 or 2.
Feb 18, 2011 | RCA 20F420T 20" TV
RCA 50in. Rear Projection rear inputs chop off top of screen
Try pressing the TV button on the remote then pressing right or left arrow buttons on the remote.
Mar 06, 2010 | RCA Televison & Video
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Optical cable is pluged in but the unit wont recognize it.
the problem is that you need to select the source on the remote of the unit and then select setup, you will be able to change the source from analog to digital (i don't remember the setting) and voila! it should work
Jul 30, 2009 | RCA RT2390 System
Operating a SONY DVD player with RCA TV
The only thing I can think of is that you have the input option on the wrong input. Have you tried pushing the input button or TV/Video button? I hope it helps...
Feb 23, 2008 | RCA F27664 27" TV
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
No signal on screen in VCR mode
I assume your plasma set has one or more auxillary (component) inputs, and to one of these is where you should hook in the VCR. You will have a video input jack, and a set of audio input jacks (probably 2 for stereo) for each of these aux. input sets. While exact setups differ, depending on your cable box(es), DVD players, and whatever other equip., a likely hookup is from the VCR video & audio outputs to one set of the aux. inputs on the plasma set. When you want to use the VCR for playback, you must select that particular aux. input with the plasma remote. Some of the hookups these days get complicated by all the equip. some have, but the above is at least a start. Thanks
Mar 13, 2007 | RCA VR622HF VHS VCR
Televison & Video Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
