Question about Maytag MGR6772 Gemini Gas Kitchen Range
Maytag gemini oven - all for burners started sparking even though controls were in the off position. Tried to unplug unit but did not resolve problem
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Posted on Oct 02, 2010
F1-1
Hi
Thanks for using FixYa. Error code F1-1 in your Maytag Gemini Indicates runaway cook in upper oven and to resolve this issue you’ll have to check the oven temperature sensor & replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Replace top burner outer coil not heating
Hi- There are a few on either side of the control panel assembly, under the covers. They like to hide them. Some models have connectors for the wiring harness to top, so you can remove whole assy. to work on it. Helps to have somebody hold top while plugging/unplugging though. Pay close attention to which wires go where when replacing element.  Let me know if this info helps- have more if ya get stuck! Thanks- Ed
Mar 18, 2010 | Maytag Gemini 30" Self-Cleaning...
When I turn the surface control to lite sparks come from the other surface controls. The burner does come on but we are afraid to leave the burner because of the sparks coming from the other controls. Do...
When one burner knob is turned to the light position, all burners will spark. Once the burner lights, just move the knob slightly so it is no longer in the light position and all sparking will stop.
Nov 12, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
Sep 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Open Questions:
Maytag MGR6772 Gemini Gas Kitchen Range Logo
281 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
