Question about Home
Looking for a diagram for a pump ITT-Marlow R75A-c
4 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: I have an ITT marlow bath spa pump which runs fine
If this motor is not turning then you will likely need a new motor. it has brushes inside the motor like a cordless screwdriver.
There are no parts for it. you will need to find another one.
http://www.uspartscenter.com/index.asp?PageAction=PRODSEARCH&txtSearch=nr2ac&btnSearch=GO&Page=1
Posted on May 08, 2009
uspartscente
  • 717 Answers
SOURCE: What is the wiring sequence for itt marlow sd 100
universal wiring on the Gemini pump since it works 50 Hz or 60 Hz
black=hot
white=common
green-ground
Posted on Aug 19, 2009
uspartscente
  • 717 Answers
SOURCE: Finding a replacemnt motor/pump for
p, li { white-space: pre-wrap; }
This Pump & Control you have is no longer being made. It hasn't been made for over 5 years. You will need the following items: • new pump • air button • air tubing You will have to change the control on the tub to an air button. You will now only have on/off options instead of the multiple speed you currently have. The link below shows the replacement pump and just under that shows an Air Button you can use and get some air tubing as well.
http://www.uspartscenter.com/ittmarlowgeminiplusiinr4a-c15hp.aspx
Posted on Feb 21, 2011
Repairs to ITT Night Mariner 160
ITT Night Vision
7635 Plantation Road
Roanoke, VA 24019
Telephone: 540-563-0371
Fax: 540-366-9015
Toll free: 800-448-8678
General email:
nv.orderadmin@itt.com
Call For Suppliers
Warranty Repair and Technical Support Toll free: 1-800-360-6054
Fax: 540-362-7400
email: nvwarranty@itt.com
Company Links ITT
ITT Defense and Electronics
Dec 19, 2007 | ITT Night Mariner 160 Monocular
Schematic for marlow tub pump 1hp model R100A 120V 11.5 amps 50/60hz
If the pump is double insulated and you have core balance circuit protection on your power circuits you don't need, if not the earth maybe put under any screw on the metal case. I'm in Australia and we have very stringent rules on pools, You should look at equi potential bonding of any metal within reach from the water. This includes metal fences, gates, rails, metal mountings of anything.I think you should call someone qualified to test your installation, preferably from the technical department of you supply authority.
Jan 13, 2014 | Pool & Spa
Aqua Glass whirlpool with a Pentair pump wont turn on.
the pictures are not showing up. Sounds like maybe you have an ITT Marlow pump that has a circuit board on the back of it.
What model number pump do you have? I believe what you tell us here is model number R150VS11-C
If this is the case then what you have is a control with a knob on the top of it that controls the 6 speeds.
The control & "VS" series pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system includes the following items:
• New 1.5 hp Pump
• AirStreme Control box and topside control panel
You will change everything from the old system to what comes with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/airstreme_system.aspx
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 26, 2013 | Home
Finding a replacemnt motor/pump for my Swirl-Way. Failed pump is an ITT marlow, 11.5 amp. Mo: R150VS-8-C, Spec: 0094C00C Any help would be appreciated
Feb 21, 2011 | Home
I dont have a wiring schematic for the itt gas valve.
The wiring diagram on the inside of the unit-has a connection diagram
Oct 20, 2009 | Goodman GMS90703BXA Heater
What is the wiring sequence for itt marlow sd 100 bath pump in uk (colour code of wiring?)
black=hot
white=common
green-ground
Jul 10, 2009 | Home
I have an ITT marlow bath spa pump which runs fine until the pump is attached when it wont start. It just sits and hums until I give the impeller a spin. Any ideas?
Apr 26, 2009 | Home
Home Logo
331 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
