Question about Canon SPEEDLITE 580EX TTL Flash
Broken flash Canon 580 EX. During the shooting inside the flash explosion occurred. I dismantled the outbreak. The closure occurred on CANON 580EX FLASH PCB. From the capacitor on the board shows a black spot on the circuit. Flash did not turn on, and nothing works. Question - What payment change? Only CANON 580EX FLASH PCB or CANON 580EX FLASH MAIN PCB also change?
  • maczot Oct 02, 2010
    Between FLASH PCB and the capacitor is insulated. Traces of a high-voltage arc is from the FLASH PCB. Elements on the board in the soot. Probably broke FLASH PCB. I am interested in statistics - how much impact damage on FLASH PCB repair MAIN PCB.
  • Canon Master
  • 12,061 Answers
Most likely that Capacitor has "Gassed" as we say. It is now destroyed, however usually too the Driver Semiconductors "Blow" as well. I have seen this before, it is not uncommon. An enormous amount of energy is stored in this capacitor and circuit, and they often fail in an explosive manner.
What you need to do, is find a Canon authorised servicing center, contact your local or head office of Canon, and inquire as to a local repair center.
Now when you take the Flash in for repair, please ask for a 'Quote" before allowing any repair work to commence, this then will allow you to make an informed decision as to repair or replace.
It is hard to give an exact cost but I would expect, that around $80.00 to $125.00 for the basic repair, would be about right for a repair. BUT depending on what exactly was wrong, it could very quickly escalate.
I think you may find, that the cost of repair, may even approach, the cost of a new unit? This is also why getting a "Quote" is beneficial.
However if you can desolder and solder, could obtain the EXACT Rating and Value Capacitor and Semiconductors, (read ALL damaged bits) and were prepared to do a little work, it is entirely possible to repair this unit oneself. but be very careful when doing so, as flash guns can give a very very nasty "Bite" (speaking from experience :) lol)
Posted on Oct 03, 2010
  • Canon Master
  • 3,083 Answers
This could just be a bad capacitor, or the boards could be damaged, it's hard to tell without checking things out with a ohmmeter. Sometimes the chemicals in an electrolytic capacitor can dry out, causing it to heat up and explode, and in that case you can usually get by just replacing the cap.
Take it one step at a time...replace the cap, if that doesn't work, replace the Flash PCB, and lastly, the Main PCB.
If you have a friend that's handy with checking out electrical components, they may be able to help.
Good luck, and try changing the cap out first. That may fix you up.
Posted on Oct 02, 2010
Can i use a Canon Speedlite 580 EX II for a canon 550D?
Yes. The 580EX II will work with any Canon digital SLR.
Nov 12, 2012 | Canon Speedlite 540EZ TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
Replace Capacitor in a canon 580 ex flash
Don't. Dangerous charges remain in capacitors and can kill you.
Oct 14, 2012 | Canon SPEEDLITE 580EX TTL Flash
I have a canon 40d and a canon 580 ex, i need to set up the 2nd curtain sync, how do i do it ? respond here or email to mqlimax@gmail.com
There is a button with three arrows pointing to the right on your 580EX. Press this until the 3 arrows appear on your flash LCD. That is second curtain sync. The other function of that button is for High Speed Sync
Jan 08, 2011 | Canon SPEEDLITE 580EX TTL Flash
My canon speedlite 580 ex is damaged. the screw base has lost the "fixing bracket" i need a repair. any ideas
you can fix it yourself with this:
http://flashzebra.com/canon580ex_footassembly.shtml
took me 10 minutes and screw driver to do mine
Sep 17, 2010 | Canon SPEEDLITE 580EX TTL Flash
Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Jun 30, 2008 | Canon SPEEDLITE 580EX TTL Flash
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
Jun 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
280 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
