Question about Microwave Ovens
Hello jsrock516, I am looking for the repair manual for Jenn-Air JER8855AAS. It seems to have been scrubbed from all souces on the internet. Do you have any ideas on where to find one? My failure symptomology is as follows: When we turned off the stove top burner, the display showed "F9," and the burner stayed energized. We pressed the CLEAR button several times and the F9 changed to "F1." Shortly after that the entire control panel lost power and has remained blank since then.
  • rick625 Oct 02, 2010
    Hello Sebin,
    The site collected my money just fine, but after processing the credit card it said the manual is not available. I'll probably have to wait until Monday to try and get the money back.
    Could I ask you to comment on the symptomology I described in my original posting?
    Thanks much!
  • 1,711 Answers
F9 is for a problem with the door latch, and F1 is a defective touch pad or clock
Here is the list with Faults.
JENN AIR FAULT CODES
Jenn Air Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
F1
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
F9
Door latch
Check door latch components.
Posted on Oct 02, 2010
  • espressonist
    espressonist Oct 02, 2010
    We have alse below the link with your stove parts layout so you understand how it is where each part located http://www.appliancepartspros.com/partse...
    From what we understand this contol panel insue you can follow these instructions
    F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
    Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
    Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
    1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
    4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
    7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
  • 712 Answers
If you are ready to pay, then you can use the following link:
https://secureiti.com/servicemanuals/ServiceManual/JENN-AIR/JER8855AAS/535216/detail.aspx
Cheers. Thank You.
Hello, i'm looking to replace my light bulb in my jenn-air microwave oven modeljmc8130dds. any help would be greatly appreciated.
The lamp is inside the oven so it is necessary to remove the cabinet but be aware that dangerous voltages are exposed even with power disconnected.
Oct 22, 2016 | Jenn-Air Microwave Ovens
Manual for jenn air microwave jmc8130dds
Like most manufacturers these days, Jenn-Air offers manuals online. I did not see specific instructions for removing the panel, but here is a link to the parts diagram which may offer some hints. You can also call or chat online with Jenn-Air Customer Care.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JMC8130DDS.pdf
Jan 01, 2015 | Jenn-Air JMC8130DDS Microwave Oven
Hello my JENN AIR Jenn Air JMV8208BAS Microwave won't turn off properly. When it comes to the end of the cooking time it beeps and the vent at the top closes but it keeps making a noise and it is still...
I would first suggest checking the bottom door switch and its mount.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
The full service / installation manual is here.
If it's not a switch issue, you may have a sticking relay on your control board, which can be economically repaired. Details are here.
Oct 15, 2013 | Jenn-Air JMV8208A Microwave Oven
I have the Jenn-Air microwave oven. It is mounted in a cabinet. How do I replace the light? Should I try to remove the microwave from the cabinet? If so, how is this done. The manual is vague on this. It...
Most microwaves are similar in design, and here is how for a GE, which will most likely apply to the Jenn Air:
http://forum.appliancepartspros.com/microwave-repair/84864-microwave-lightbulb-replacement.html
This site explains the process:
http://forum.appliancepartspros.com/microwave-repair/165-microwave-interior-light-bulb-replacement.html
To discharge the cap, you can touch an insulated screwdriver across it's terminals, but just avoid the contacts and you will be fine.
Sorry to have to relay tough news, but how this helps you repair it.
Sep 10, 2010 | Jenn-Air Microwave Ovens
I have a Jenn-Air M170 & parts of the inner door have cracked and broken, exposing the interior metal. Can the door be repaired or do I need to replace the unit? Does Jenn-Air still make this model?
Yes you will have to replace it, and yes, i am fairly sure they still have that part in stock. please use the direct link below to ask and obtain the part you need.
Also please ask them for the service manual too, this will make the task ever so much easier.. However the replacement parts used to come with fitting instructions..
http://www.jennair.com/flash.cmd?/#/page/customerservice
Aug 19, 2010 | Jenn-Air M170 Microwave Oven
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
My jenn-air microwave makes a LOUD humming noise
More than likely the power inverter board has been damaged and it would be best to stop using it immediately.
Jenn-air products are very good quality and quite expensive to replace. I would contact Jenn-air service and have a service tech dispatched to determine the exact problem and the cost to repair it. Jenn-air stands behind their product 100% and should be able to repair the unit for you.
http://www.jennair.com/content.jsp?name=local_service_repair
Follow this link to Jenn-air service and repair.
Cheers,
Keith
Jan 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Jennair Microwave Model JMV8208AA/AC
I am in need of a Jenn-Air JMC7000ADB (black) microwave, so if anyone gets tired of trying to solve the problem, I will buy your microwave from you.
Call Mike at 317-557-5352 or e-mail mslshihan@aol.com
Thank you.
Sep 30, 2008 | Jenn-Air JMC7000 Microwave Oven
Need Replacement Plate
Look on the internet auction sites (ebay etc)
There is quite a trade in them. Make sure match the dimensions of yours before purchase.
Jun 11, 2008 | Jenn-Air JMC9158AAS Convection/Microwave...
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
