Question about LG 37LC2D Television
LG 37LC2D TV - after turning on, screen remains black for 5 minutes or longer, then it starts to flash white rectangles of varying sizes. That continues for several minutes, then we have sound and picture. After about 30 minutes of good sound and picture, the screen suddenly goes black and no more sound. Eventually, it will turn itself off.
  • LG Master
  • 17,129 Answers
This is a sort of slow start up and it can be a fault in the Power supply as the voltage builds up or in the display drive section where the fault seems the same as a circuit trying to act upon. There is a defined failre but only if the observations of the voltages are taken out and confirmed.
Start with the Power supply and check if the filter and storage capacitors are topped up with the designed voltage, if there is slow build up then check the reason if in the drive for poor swithching or a poor capactior.
Next check the same with the main board , look for IC's getting warm , if so use a freeze it to cool and set the picture to start up therby confirming the IC. repeat check, observe for heat and changes in voltage.respond
please try this link for tips:
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Posted on Oct 02, 2010
I have an LG model 37lc2d the screen is black but has illumination and no sound at all and the green power light flashes 16 times upon powering up?
Things to check: Make sure your TV is set to the correct input.
I DK about the light flashing 16 times but that could be a stuck key on your remote control. If you can, urn off your remote and try turning on by hand and going through the "INPUT" choices to make sure you have it on the correct setting. BTW, if your TV is 5 years old, you'll make the money back in no tie if you get a new "Energy Star" TV. The new Energy Star TVs run on very little electricity compared to 5 years ago.
Jul 03, 2012 | LG 37LC2D Television
My LG 37LC2D picture suddenly goes black and then if I bang on the corner of the set sometimes the picture will return. What is wrong with my TV?
could be the power supply card(s) is unseated..open it up if you dare and re-seat and/or maybe remove and clean the card edge connector contacts with an eraser
May 27, 2012 | LG 37LC2D Television
Tv powers up, runs for about 5 minutes then goes to black screen, cant do anything with remote, unplug for a while, turn on ,, same result ?
You may have dying power supply problem due to bad DC filter caps, poor solder joints in the power supply or the backlight inverter board
Jun 08, 2011 | LG 37LC2D Television
My 37LC2D takes about seven minutes to come on after I turn the unit on. There is a red flashing light on the lower right hand side of the screen.
Does the unit work ok when it eventualy starts up? if so it would suggest possible dry solder joints in the power supply section, high value resistors that have changed tolerance,dried out capacitors? but if this was the case you would expect to see some visual picture problem, picture size problem or an audio hum?? these type of faults you would expect to see with age, ie if the unit was 3/4 yrs old. You will need a techie visit,sorry.
Nov 03, 2010 | LG 37LC2D Television
LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
May 09, 2010 | LG DU-37LZ30 37 in. LCD HDTV
When you turn on the TV the screen flashes through a sequence of red, green, blue, white & black screens. Unable to access menu & no sound. TV Model LG 27LC2D
Sounds like it's in a service burn-in mode. LGs need a service remote to de-activate. Probably easy for a local LG shop.
May 03, 2010 | LG 37LC2D Television
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
389 people viewed this question
Computer Repairing
Computer Repairing
