Question about Vacuums
My Oregon Scientific BAR888 has 5 windows, 1. temperature, 2. humidity, 3. mb/hPa or inHg (switch at the back), 4. bars showing pressure changes over 24 hours, and 5. time/date. Window 3 gives an option to set something between 0 and 2500. Oregon say they only have one set of instructions for the BAR888 but they do not match my instrument as there is nothing included for my window 3. Trouble is I don't know what the 0 to 2500 relates to and therefore don't know what to set it at.(My model does not have an atomic clock.) Grateful for advice please or where to find the right instruction manual. Thanks.
  • 1177 Answers
SOURCE: Hello, On the 24 of June
I'm a little confused about this question. You bought it in Budapest but live in Israel? This could be why the clock is wrong. Many of these Weather Stations (it would be helpful to know the model number) have radio controlled clocks, which pick up a signal broadcast from an atomic clock, but there are many such broadcasts, depending on where you are. In the UK we can get our own atomic clock or Germany's, and if one has a German model weather station or clock one needs to adjust it to a different time zone from the default to get UK time.
Oregon Scientific have an extensive web site with manuals for download, but without knowing the model, I would not know which manual to download to help you with the thermometer issue, or indeed the clock setting. I assume (you don't say) that the outdoor sensor is wireless. If so, there are usually three channels for the link, and both the station and the sensor have to be set for the same channel.
Posted on Dec 13, 2010
  • 731 Answers
SOURCE: I have a Sio/Scan Atomic
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
Posted on Jan 03, 2011
  • 30 Answers
SOURCE: We have an Equity
Good afternoon,
Equity has the instructions on their support page, but no actual instruction sheet is available:
Hope this helps! Please rate this solution.
Posted on Mar 05, 2011
Testimonial: "Thank you for your help! I was dreading having to return the clock if I couldn't set the time or year. BTW - It's a clock; not a vacuum."
  • 710 Answers
SOURCE: Model 31320 SkyScan Equity Time
You press and release the mode button, then press the adjust button. This is what the instructions say to do. However, I see that you don't have an adjust button listed. I would try pressing and releasing the mode button, then pressing the ZONEDATE button and see if that will do it.
If this works, please place a vote for me. Thanks,
Handie Andie
Posted on Mar 27, 2011
  • 17 Answers
SOURCE: my oregon scientific projector clock
A time zone is section of the country that adjusts for daylight savings time. The United States is composed of four time zones - Eastern, Central, Mountain, and Pacific. Each county is assigned to one of the four time zones. See the attached map to see which time zone you are in. Then you must set up your clock to match that time zone. bblue1967191.jpg
Posted on May 03, 2011
Testimonial: "fast response"
How do I put on the belt
Normally fairly simple.............1)Remove the bottom plastic cover. Should be 2 or 3 screws. 2) Pull the bar out (along with the belt) 3) Put new belt around the bar on the smooth surface. 3) Put bar back in (It goes a certain way, but easy to tell by the ends of the bar 4) Stretch the belt back to the small round metal pole. It should be tight, so sometimes takes a litlle muscle.
Jun 04, 2014 | Dirt Devil Vacuums
Reset button inoperative
Sounds like 1 of 4 possibilities
1.The button next to your on switch is jammed.
2. The Motor has burnt out within the head unit
3. The PCB Unit is faulty wihin the head unit
4. The thin wires running down the inside of the machine to the head unit hve br
May 23, 2014 | Dyson Dc-18 "slim" Upright Model...
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
Re: Low pressure on WhiteWing steam cleaner
1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
3. Make sure the safety cap is tightened.
4. Make sure you have enough water in the tank (at least half a bottle of water)
I hope this helps.
Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
I recently purchased and installed an Oregon Scientific Model WMR200A. The rain gauge worked for the first rain fall but it has not worked since. Today we probably got 3 inches of rain but it registered ...
Oregon Scientific has an FAQ webpage for your weather station:
There are several Q & As that are pertinent to your problem.
I hope this helped you.
Good luck from Detroit, MI.
Jul 19, 2011 | Vacuums
My oregon scientific projector clock keeps changing time, I think it might be something to do with the time zone. I do not know what a time zone is?
May 03, 2011 | Vacuums
I replaced a Intermatic light timer with a GE 15086 timer. I have read several solution, but none fit my wire sceme. This is hooked up as a 3-way switch so the second switch can turn outside lights on...
1) GE 15086 is not a 3-way timer.
GE programmable timers are for single-pole switch replacement only. I have tested this timer, and own several GE timers, and many other brands.
2) Open following link to identify timers that work for 3-way switching.
3) After buying correct timer, then you need to review wiring diagrams carefully because the timer replaces 1 of the 3-way switches, but other 3-way switch has to be wired exactly right to match your brand of timer.
4) Links on page above show manuals for each of the 3-way timers. Compare wiring for each timer with Intermatic wiring that you are replacing, because Intermatic is wired differently than Aube.
5) Or just buy another Intermatic ST01C or EJ500 or EI400, etc, and wiring with change out 1 for 1.
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Vacuums
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Why did the brushes stop rotating?
It could be a few different reasons, 1. The belt is broken, 2. The motor has died, 3. There is an obstruction, or some such thing stopping the bar from rotating (often hair and/or string) 4. The contact switch is defective. (switch that turns beater bar on when handle is tilted back) Hope this helps
Sep 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Kenmore Elegance Vacuum cleaner - power bar not working
The problem almost certainly is that the axle of the brush in your power bar has dirt/fluff in it that is preventing the belt from turning it so that the fuse in the power bar clicks off after 2 or 3 seconds. It is fairly easy to fix. All you will need is a Phillips screwdriver and about 15 minutes. Follow the following steps
1. With the power bar disconnected from the vacuum, turn it upside down and you will see two inset screws at the rear side of the base of the power bar. Unscrew these two screws using your Phillips screwdriver.
2. With the power bar in the same position unlatch the two plastic tabs at the rear of the power par. [It may be useful to flip up the metal bar that you see on the base to use as a handle] On each side of the base you will see an arrow saying insert screwdriver here to release. Insert a screwdriver and lever the plastic of the base slightly apart from the plastic of the side. When you have done this for both sides the base should lift off.
3. Now lift the brush including the two end pieces straight up. It should just slide up. You will need to unhook the drive belt from the brush as you lift it out.
4.Pull of each end piece and clean the dust, lint, hair off the end piece and from inside the end of the brush.
5.Once clean, reinstall the end pieces on the brush. Hook the belt back over the brush to its original position and slide the brush back into the power bar.
6. Reinstall the base by hooking the tabs from the front of the base into the small openings on the power bar.then push the base down until it clicks back into place and the tabs are back in their original position. Reinstall the two screws you removed earlier.
7. The power bar should now work. Good luck.
Mar 05, 2009 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
81 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
