Question about Garden
How do I switch the Weed Eater Barracuda 2595 from vacuum to blower?
  • fplady Oct 02, 2010
    Yes.
  • fplady Oct 04, 2010
    Thank you.
    You've been a great help.
  • 712 Answers
Are you looking for an user manual?
Posted on Oct 02, 2010
  • 2,841 Answers
Your Barracuda has a inlet restrictor installed that must be removed when you use it as a vacuum. With the unit unplugged and off, open the inlet cover by inserting the tip of a screwdriver into the latch area on the vacuum inlet cover. Gently tilt handle of the screwdriver toward the front of the unit while pulling on the vacuum inlet cover with the other hand. Turn the inlet restrictor located inside counterclockwise to remove it from the unit. Do not close the inlet door. You will next attach the vacuum tubes. There are 2 tubes, a lower and upper. The upper tube is cut straight on both ends and attaches to the blower unit. The lower tube attaches to the upper tube and one end is cut at an angle. Locate the arrows on the upper tube and the arrows on the vacuum inlet areas. Line the arrows up and insert the tube into the opening on the unit and then twist clockwise until it seats. Install the collection bag over the blower outlet and secure with the velcro strap. You are now ready to use the unit. Here is the owner's manual with instructions and photos. http://72.3.225.179/manuals/545117523e.pdf
  • NOT ME Oct 03, 2010
    To go from vacuum to blower just reverse the process.
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
Need to switch weed eater barricuda from blower to Vacuum but no manual
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/2500_series.html?idRes=15826113
Here is where you can find the manual to download for the 2500 series Weed Eaater blower/vac
Aug 29, 2011 | RTO Weed Eater Electric Barracuda 2595...
My leaf eater starts to smoke. Where, or is there a place to oil the moter?
the electric motor should not need oiling sounds like you are running on a lightweight ext cord and under powering motor try hooking up to a plug directly into outlet see if problem persist
Nov 07, 2010 | RTO Weed Eater Electric Barracuda 2595...
Looking to replace my vac, bag if possible
http://www.ereplacementparts.com/vacuum-bag-kit-fits-types-p-229821.html
Oct 29, 2010 | RTO Weed Eater Electric Barracuda 2595...
Where can I obtain a replacement vacuum bag (in Calgary). The zipper on mine has broken making it unuseable.
Go to http://www.ereplacementparts.com/weed-eater-parts-c-17589.html Enter your model number. Then click one of the thumbnails that comes up until you find the replacement bag. My model number was 2595. I clicked on the thumbnail in the top row on the right and found the bag (part # 15). You can order direct from them and they ship right to you.
Sep 29, 2010 | RTO Weed Eater Electric Barracuda 2595...
How do I attach the vacuum bag and get it to work
There should be an air intake grille of some type, the bag should have a round opening that fits over a collar around the air intake, it may be held in place by a Velcro strap.
You don't give much detail to go on.
May 25, 2010 | RTO Weed Eater Electric Barracuda 2595...
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Jun 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
I have a Weed Eater Barracuda leaf blower but don't have the manual. How do I attach the vacuum bag?
Copy and paste. It will take you to .pdf for your Barracuda
Apr 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
Garden Logo
1,283 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
