My Central AC Unit is leak
My Central AC Unit, Inside, is leaking all over the carpet. I live in Houston and the humidity just kicked in and that is when it started. I am sure that is what is causing it but I do not know how to fix it. Do you have any suggestions or advice?
Mike
  • 828 Answers
There is a drain system on all A/C system cooling coils. Your drain is restricted or plugged. Finding the outlet you can blow back through it to dislodge an obstruction. Alternative is to replace the drain tubing or piping.
Posted on May 27, 2008
I have a Kenmore C120 portable air conditioner. It is leaking water from the back bottom. There is a white drain but this unit is supposed to self evaporate. At least it did last year. Now it is leaking...
Interestingly, your Kenmore Portable AC is manufactured by Delonghi. Occasionally, what you are experiencing happens when the humidity level is high and the air intake filter needs to be cleaned.
That also means that you will need to drain the tank, at least once.
You know where the drain plug is, so you can either carefully take it outside to drain or put a low sided container, capable of holding 1 1/2 quarts of water under the drain plug. If you drain it inside, turn the Master ON/OFF Switch to OFF and unplug the unit, before attempting to drain it.
Hope this helped you to solve the problem.
Jul 13, 2011 | Heating & Cooling
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
Unit is leaking all over floor
Can you connect a pipe from the drain pan to a drain? This would get rid of the moisture within the room instead of just recycling it.
Jul 20, 2010 | Haier HPM09XC5 Portable Air Conditioner
Accessive moisture on the inside of vehicle
you dont supply enough info. if it is excess humidity you are probably trying to drive with the heater on reciculate.the humidity is from your breathing this is only to be used when the AC is needed in its coldest funtion. if it is an oily kind of moisture or a sweet tasting liquid in the carpeting toward the heater it is probably from a leaking heater core. if its just water in the carpeting have someone spray water on the winshield and door areas until you locate the source of the leak.
Feb 19, 2010 | 1995 Isuzu Trooper
The water that drains from the airconditioner to outsied is clogged up and not draining how can i unclogg it myself?
I can tell you a few stories of my own - I've had this problem myself and water will eventually build up and leak inside your house - you don't want it to leak on your electrical outlet ! I do not know how long you had this unit or how old is it, but these things can happen over time due to dirt, dust or other foreign objects or rust. Some AC units have fan spinning and picking up the water and spraying it on evaporators, most of it should be evaporated - only excess humidity will cause dripping - on older models water should drip outside through an opening or two at the back of the AC unit.
Make sure your AC is not level, and is tilted about 20 degrees outside, allowing the water to flow outside the AC unit.
You will need to find a way to access your AC unit from outside, locate the areas where the water drips normally, you should see openings, using an object (paper clip, pipe cleaner, etc.) try to insert it in the holes back and forth until you dislodge whatever is blocking the hole - be careful not to damage the very deliate fins at the back of your AC.
if still no water drips then take a ladder and climb up and you shuold be able to see from the inside there should be a slope or container where water accumulates before dripping out, is there ANY water there ? If you mostly see water farther away then your AC is probably not tilted enough to allow water to flow out.
If there is neither any water towards the outer edge where it drips, nor inside, farther away nor dripping inside your home, then it is probably being all evaporated or your humidity level is under control. The more your air has moisture the more water will be produced inside your AC, any excess moisture will accumulate inside your AC - if your AC manages to evaporate all of it, and no leaks inside, good for you, I wouldn't touch it.
Another tip - when you shut down your AC, do you hear swishing and unusual sounds of water ? that could mean accumulated water not being evacuated - Although it IS normal for some stagnant water to remain in your AC - do not worry about that, as long as it doesn't leak inside.
Sep 01, 2009 | Heating & Cooling
Central AC leakage
Sounds like the drain pipe isn't large enough or not set at enough down angle to handle the water on high humidity days,check it out
Aug 22, 2009 | Heating & Cooling
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Jul 11, 2009 | Soleus PH310R03DB Portable Air Conditioner
04 trailblazer AC leaks
Rather than pay the dealer $350+ to fix this, I found the "L" shaped drain hose behind and interior to the front passenger tire (I let the car idle with the AC on and waited for a drip. On my back on groud I reached in and found the drain line and it came off i my hand and about 4 oz of water and some decayed matter floowed out. I reaced back in and found the hole to which the L line was attached. It was a rubber fitting on the end of a metal pipe. The fitting came off easily and then about 8 oz of water flowed out (carpet had been soaked for two days). I reattached the L drain line and noticed that inside the fitting was about 1/4 tsp of "mulch" - decayed leaves, pollen, etc. Reattacted the fitting and water now flows freely out the drain. And yes, its a very high humidity area - Houston, TX. And if you live anywhere near here you know about the intense yearly dispersion of Pine tree pollen. I thisnk that accelerates the blockage. Happen about every 2 years. (Third time for me. First two I let the dealer over charge me for this effort. BE SAFE WORKING UNDER YOUR CAR!
Jun 22, 2009 | 2004 Chevrolet TrailBlazer
Unit leaking
leakage from my central air unit from drain pan, please help
Apr 29, 2009 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
234 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
