Question about Kenmore HE2 Plus Front Load Washer
Front loader Kenmore HE3 drains but after several hours water accumulates in the machine. I can then spin it out but it will reaccumulate.
    President:
  • 1,430 Answers
Thye problem is the water inlet valve is hanging up. The valve will need to be replaced. They sometimes get debris inside and stop seating. They are usually inexpensive and easy to replace. Here is a link that should help Water inlet valve replacement
Posted on Oct 02, 2010
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore front loader does not go into the spin cyclr and water is left in the drum
Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
Washer will not drain and spin. Have checked the
If you have room and empty 5 gal bucket try to lower your drain hose to see if there is any water coming from. Other should be points on programer or small motor that spins programer.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What is the most common reason for my washer to leak water
leaks are usualy from the drain or fill pipes, or door seal(front loaders), and lastly, the pump.
I recommend starting at the hoses, then check seal, then pump
Nov 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
