Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can i connect speakers directly to Audio R L output on Sharp Aquos LC?
  • Sharp Master
  • 9,587 Answers
NO. The outputs are at line level. You'd need an amplifier between them.
Posted on Dec 31, 2014
  • 86 Answers
SOURCE: Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
Posted on Jan 20, 2008
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
dsacco86
  • 1077 Answers
SOURCE: Aquos LC-37D64U - I've got a Motorola DSR505
You have it hooked up right. I found something on page 26 of your manual. Look at the HDMI setup section. I think that maybe the problem there. It's an audio select option for input 5.
Let me know if it works.
Posted on Apr 24, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: connecting external speakers to Sharp LC-32SB23U
Invest in a sharp soundbar (about $175.00) matchs the cecor of the TV fits right at the bottom and looks like part of the TV and the sound is super.
Posted on Jun 04, 2009
My sharp aquos tv LC-60LE632U has picture but no sound, What can be done?
Check the audio 'output select' under the Systems Settings menus. The output may be set to 'variable'. Set it to 'fixed' so that the audio runs through the speakers.
Oct 12, 2014 | Sharp AQUOS LC-60LE632U 60" LED TV...
Sound
Your TV has both analog and digital sound output jacks. You will need to connect to an audio amplifier/speaker system that can use either of these types of audio signals. Consult your TV user manual for more info.
Mar 22, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I want to connect microlab speaker to my sharp aquos 46" tv. please guide me how can I connect 6 plugs of the speaker to the rear of the tv? Thanks
Hello.
You can not connect any speaker to TV directly.
You TV have non-amplified output on the back "Audio out" that you connect using red and white RCA style cable into home theater system or some other audio amplifier. Amplifier itself should have outputs for speakers. Amplifier and speakers have to match. If you have just bare speaker/speakers I would recommend to get rid of it and purchase cheap home theater system that would definately solve your problem. They come with instructions and diagrams of how to connect it to TV.
Regards.
Russ.
Dec 01, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound from TV - Sharp TV LC-32GPIU
Check to make sure you have the speakers tuned on in the setup menu, and you are not in sap.
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How do you connect external speakers. Which
use hte head phone output as the speakers have that jack plug
Jun 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound from audio output This set is new.
The speakers need some kind of amplification, if you have something like a set of computer speakers connected and they are not powered they won't work, try connecting them to the headphone jack.
Let me know the set up, what kind of speakers, audio settings from the tv menu.
lone99star
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
