Question about Mitsubishi VS-60603 60" Rear Projection Television
Hi Recently I had Direct Tv come out and add a dvr to my Tv it worked fine till after the guy left, we dont use this tv often. It turned itself off and now when I try to turn it on the tv turns itself back off. It doesnt even stay on 2 seconds. Ive tried unplugging the tv and that doesnt work, I also tried holding the power button in with the menu button that does nothing. Can you help me?
  • 1 more comment
  • dhazel1768 Oct 03, 2010
    When I use either the power button on the tv or remote the light on the tv comes on then shuts right off. I can hear it click on and shut off.
    I have an electrician here now and need help getting it down to a component level. I dont have the manual for the tv, no warrenty due to the tv was bought in 98.
    Is there usually a specific one that goes bad?
    President:
  • 2,777 Answers
So the power button on the TV itself, and the remote power button do not work? Neither one will get the TV to power on and stay on? If so that is a very bad sign for the TV and is unrelated to the directv...
Let me know if that's the case and I'll tell you what's going on here.
Thanks Tim
Posted on Oct 03, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 03, 2010
    Yikes, that is very bad indeed :(. Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
    So sorry that I don't have better news but it is definitely a power issue internally.
    Thanks
    Tim
  • Tim Grayson
    Ok well tell him it's most likely a capacitor or some chip on the power board inside the TV. He should be able to find it I'd imagine. Have him trace the power as it comes into the TV...
    Tim
  • Tim Grayson
    Definitely no usual one that goes bad, it could be anything on the board, especially with this age of TV..
    Have him check out the video board as well, but I am quite certain it is in the power supply. If voltages coming out of the power supply are normal though it must lie in another component, from there it could be really anything, video board being the most likely.
    Thanks
    Tim
Model ewt1321 emerson tv stuck on channel22 so direct tv will not work snow only
with the set turned off --unplug it for a few minutes and plug back in which may allow it to reset itself
Mar 23, 2012 | Emerson SpongeBob SquarePants TV
We recently connected to Direct TV...I want to transfer some old western TV Shows I recorded on my Direct TV DVR Recorder to VCR Tape. I was told by the people at Direct TV that I would need to contact you...
You can try this: Connect your DirecTv to VCR with Red/White/Yellow cables. Then the VCR to your TV with the same type of cables. Make sure the VCR is set to the video input, not the tuner. Turn your TV to the correct video input. Get the program ready on the DVR as if you were going to watch it. Press record on the VCR and then play on the DVR. At the end of the program, press stop on both. You may have a problem with the video recording properly. Some stations broadcast with copyright protection.
Apr 12, 2011 | Emerson Televison & Video
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Phillips TVO Directv DVR keeps freezing up...what can I d to correct this?
Try resetting reciever by holding power till it turns off then pull the card. let it reboot and ask for the card, reinsert card and it will reboot again. I problem keeps happening, try to force software updade by, restarting. On the Directv screen (first screen while restarting) press 02468. keep pressing it over and over if you have problems catching it at the right time. It will then go to a blue screen with a load bar. this should solve any conflicts.
Sep 13, 2008 | Philips DIRECTV R15
Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Mar 26, 2008 | Televison & Video
Codes to program Innovage Products Jumbo Universtal Remote
I need the code for my rca tv so I can program the inovage jumbo universal remote Pleaseeeeeeeeeeeeeeee
Dec 31, 2007 | Televison & Video
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
I believe the cable guy is correct and I will suggest you call for professional help now,if you try to use it like this the problem might become expensive.
Sep 23, 2006 | Sony KV-35S66 35" TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
