Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a new Husqvarna chain saw and I can't get gas to the primer bubble. I followed the manual's instructions but no gas will enter the bubble when I pump it.
  • 784 Answers
Maybe problem with valve!
Posted on Mar 18, 2011
Why does primer bulb suck bubble when pumped on my ryobi 46cc chainsaw
you have a hole in your gasline they dont cost much but finding it is the thing hope this helps
Aug 15, 2014 | Ryobi Chain Saw. 20 in. 46 cc Gas Chain...
The saw s primer bubble split ...i replaced the primer and it ran fine..then just quit... i changed the gas and checked the plug for fire .its ok..........but it will not fire ????
I would see if you have a air pocket in your gas lines.Try removing plug and pumping primer bulb until you know engine is flooded. Then let dry out before you put plug back and try to start. Thank you.
Apr 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Primer bubble
The primer bubble just pulls fuel from the carb and dumps it back to the tank, to replace it diss connect the two hoses, there are then two small plastic legs on the back, press them both in and the primer will just pop out.
Feb 26, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Trying to find an owners instruction manual for Husqvarna E. series 450 , 16 in gas chain saw.
Umm. Husqvarna makes both sewing machines and chain saws (good ones). But this needs to be posted in a category other than sewing machines. I would suggest "Home & Garden/Patio & Garden" as the most likely one I could find for you. Good luck.
Jan 26, 2011 | Husqvarna Sewing Machines
I have a Husqvarna 455 about 2 years old. At about 1 year point it would no longer start using the primer pump button on the side when cold. If I take off the air cleaner and give it a a shot of gas down...
Your seeing the problem. Air in the fuel lines usually caused by a cracked fuel line or a pin hole in the primer bulb. Until you can stop the air bubbles by either replacing the actual primer bulb or fuel lines your always going to have the hard to start problem. This can also cause the engine to run lean at high RPM settings and eventually burn a hole in the piston. You should repair the fuel problem ASAP. If you do not find any fuel line / primer bulb problems then it is time to start looking at the carb diaphram.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Husqvarna Chain Saw 20" Bar
I have a husqvarna model 50 chain saw and am not sure of the ratio of the oil & gas mixture.
Husqvarna Rancher 50 1982-11 OM Follows:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
50:1 according to your manual if using Husqvarna (quality) 2-cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna 385xp leaks gas when held on side, does not leak when held straight up. Saw about a year old use to rip lumber subject to a lot of vibration and running wide open.
Hello J
An example Husqvarna "IPL, 385/ 390 (EPA), 2006-10 ,Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601137.pdf
I think pn 544 32 49-06 on Detail H is a fuel vent hose that has cracked or become disconnected. It appears the only other hose is the carburetor feed. If my saw and one hose has failed I would change both.
All 385 IPLs can be found here:
HusqvarnaUSA.com
06 1500198
Lou
Mar 18, 2010 | Husqvarna Chain Saw 20" Bar
My Husqvarna 345 Chain saw leaks gas when I fill it up . It stops when I put the saw in the upright position. Jim
I suspect a bad fuel line between the primer bulb and fuel tank. If 1 is bad it is probably a good idea to replace them all.
Typical fuel system and a tip or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week HTH
Lou
Feb 15, 2010 | Husqvarna Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
