I keep getting error code "J01" to remove misfed paper on my Panafax UF-7000-AUJ. I have removed print cartridge/drum unit, removed paper tray, removed some of the paper, checked in the back--BUT STILL KEEPS DOING IT! Also, when I first close the cover in front of the print cartridge/drum and the machine starts trying to print my faxes it makes a brief scheeching noise--ominous. Anything else I can do myself?
  • HemOnc Oct 02, 2010
    Thanks, I may have to wait and call for service on Monday. I see two sets of "springs" on either side along the track where I slide-in the print/drum cartridge. Is one of those the problem?
    Thanks. I left a message to request service on Monday.
  • 4,737 Answers
In your printer, there are two Switch Actuators (regulator/sensor) beside the Cartridge compartment. You will be able to see it after the cartridges are removed. Try to gently push or pull clip. It might have been stuck on the passage.
Sometimes, simply pushing and pulling out a bunch of papers can clear the obstruction. You can also try this, Remove the cartridge/s, drum and the fuser unit, now take a blower or air can or vacuum cleaner and clean the passage with the respective selected machine.
Actually, locating the actuator isn't a simple job, in most cases, we need a tech to do this task. If you can't locate it, you better call a tech who knows about printers and get it fixed for you than messing around with it. You may damage another components
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 02, 2010
  • 567 Answers
We need to remove the toner cartridge. There will be two switch actuators at the bottom.
From your description, it seems that there is an issue with one of those.
Try to clip the actuator back, that might help you in resolving the issue.
This is a rather difficult job, I mut say. You might want to have a service tech deal with this problem.
  • Anuj Joshi
    Anuj Joshi Oct 02, 2010
    Yes, exactly.
    The reason i suggested that you involve a tech is because this is a rather complex procedure.
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I am having an issue with a Panafax uf-8000 printer. It grinds when starting up and says there is misfed paper. Don't see any.
Paper feeder sensor guide is open or displace ,So it said misfed paper.Clean sensor or right position set the sensor guide.
Dec 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
J01 error, but no paper jam; can't re-set
Remove the toner cartridge.
There should be 2 switch actuators sticking up from the base.
It sounds like one of these actuators has been knocked loose. Try to clip the actuator back on to the sensor.
This is a TOUGH job, you may need a sercive tech to look at it.
Oct 13, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I JUST CHANGED THE TONER AND THE COPIES ARE PRINTING OUT WITH A HEAVY THICK LINE ON THE SIDES
Indication Cause and remedy Page
Drum replacement
required indicator
Steadily
lit
Replacement of drum cartridge will be needed
soon. Prepare a new cartridge. 70
Blinking Drum cartridge must be replaced. Replace it with
a new one. 58
TD cartridge
replacement
required indicator
Steadily
lit
Replacement of TD cartridge will be needed
Blinking TD cartridge must be replaced. Replace it with a
new one. 57
Misfeed indicator Blinking
A misfeed has occurred. Remove the misfed
paper referring to the description of "MISFEED
REMOVAL".
63
SPF misfeed
indicator Blinking
An original misfeed has occurred in the SPF.
Remove the misfed originals referring to the
description of "D: Misfeed in the SPF".
67
Power save indicator is
steadily lit.
The unit is in the preheat mode. Press any key to
cancel the preheat mode. 54
The unit is in the auto power shut-off mode.
Press the start ( ) key to cancel the auto power
shut-off mode.
54
The paper tray indicator is
blinking.
The paper tray is not installed properly. Push the
tray into the unit securely. –
"CH" is blinking in the
display.
The TD cartridge is not installed. Check if the
cartridge is installed. 57
"CH" is steadily lit in the
display.
Side cover is open. Close the side cover
securely by pressing the round projections near
the side cover open button.
"P" is blinking in the display.
The paper tray or multi-bypass tray is empty.
Load paper. 15, 17
A misfeed has occurred in the paper tray or
multi-bypass tray. Remove the misfed paper. 63
A letter and a number appear
alternately.
The scan head locking switch is locked. Unlock
the scan head locking switch. 9
alternately.
The unit will not function. Turn the power switch
off, remove the power cord from the outlet, and
contact our Technical Assistance Department at
1-(630)378-3590 in the USA or 905-568-7140 in
Canada.
May 13, 2009 | Sharp Office Equipment & Supplies
Panasonic UF-7000 Fax - paper jams and noise
Sorry to say you probably have a broken gear on the fuser assembly.
Very expensive to fix.
Mar 09, 2009 | Panasonic PanaFax UF-7000 All-In-One Laser...
ERROR CODES 016 AND 010
Unplug
move ink cartridge to center
remove ink cartridge
knock off the mountain off dried ink where the ink cartridge normally sits
plug back in
press function 7
tel/dial key slowly 4 times
set
91
set
1 (for off)
set
stop
look in the bottom of the paper tray and push backstop flush up to the paper
Jan 03, 2009 | Panasonic Panafax UF-333 Plain Paper...
My Dp-180 has an error J01
there is a tab at the back of the tray , make sure it is pinched up to the paper.. and take all the paper out and see if there is any folded paper at the bottom it not.. msg me directly and we can try one more thing
Dec 23, 2008 | Panasonic WORKiO DP-6030 All-In-One Laser...
Paper jam in back top area of a konica minolta 2400w bob.crane@ihug.co.nz
moz-screenshot-7.jpgClearing Media misfeeds
To avoid damage, always remove misfed media gently, without tearing it. Any pieces of media left in the printer, whether large or small, can obstruct the media path and cause further misfeeds. Do not reload media that has misfed.
Note
The image is not fixed on the media before the fusing process. If you touch the printed surface, the toner may stick to your hands, so be careful not to touch the print face when removing the misfed media. Make sure not to spill any toner inside the printer.
Clearing Procedures
1. Pull the lever, and then open the top cover. If there is paper in the output tray, remove it, and then fold up the output tray before opening the top cover. Do not touch the transfer belt.
2. Slowly pull out the drum cartridge. removed drum cartridge on top of the printer keep it close and insure it is safe and stable where it sits. Be sure to keep the drum cartridge horizontal and place it where it will not become dirty.
Do not leave the drum cartridge removed for more than 15 minutes, and do not place the removed drum cartridge in a location where it would be exposed to direct light (such as sunlight).
3. Remove any misfed media.
4. Reinstall the drum cartridge
5. Carefully close the top cover
I hope this helps you and thanks for your question.
I the problem persists let Fixya know and we can detail a few items to check in order to determine the cause of the frequent misfeeds.....thanks........Whytfang
Aug 28, 2008 | Konica Minolta magicolor 2300DL Laser...
Panasonic PanaFax UF-490 Problem with Drum Unit
for manual setting.. when replacing the drum unit.. press function 7 thend scroll down select maintenance then scroll donw select drum unit then press 2 to clear the usage.then press 1 for yes.
jamming or misfed?
try to check the drum unit you install.see if the drum not installed properly. turn off and on the unit
Aug 02, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
154 people viewed this question
k24674
jasbo
jasbo
