Question about Yamaha RX-V595A Receiver
Center speaker still not working :(
Hi Sakelliou,
Do you mean do a speaker test? (what is a channel test?) We can hear out of all speakers when we do the test, but then when we watch tv, we can't hear out of all the speakers... I'm not sure what to adjust on the receiver so we can hear out of all. I don't think it's jsut the dvd disc because it happens with everything we watch (unless we put the sound on disco mode). Can you help?
  • Yanivrachel May 31, 2008
    Hi Sakelliou,
    Can you explain how to set the internal sound generator to a movie function. We tried put something on movie theatre mode, but it didn't fix the problem.
    We normally have the setting on Pro-Logic, but we can't hear anything/control the volume of the center speaker.
    Any ideas?
    Thanks!
  • 95 Answers
All your speaker channels are working so your problem lies with a setup fault. when you watch tv you are only feeding a stereo signal into the amp. you need to select the internal surround sound generator. you need to select either the movie or surround function. the unit will convert the stereo signal to 5.1 channel surround.
Posted on May 27, 2008
Why does only center channel speaker work?
Try running a sound test. You should have a test mode that will play a sound through each speaker to see if you have them hooked up correctly. If you still only hear it from the center, unhook the center and connect it to another speaker output, say right front. Run the test again. If you hear something from that center speaker, its the speakers. If not, try each speaker output to make sure the results are the same. If so, you may have an internal board problem.
Good Luck!
Nov 05, 2015 | Denon Avr-1910 Receiver
Why is my centre speaker not working on my stereo setting on phono?
Records are binaural only. There are only two channels of information, left and right. There is no signal available for a center channel.
Aug 29, 2014 | Technics SA-AX730 Receiver
Back ground sound is so high you can't hear the dialog ,meaning having \r\nto turning ssound up way too high
This can mean only one thing. Your center channel is not working. Either you have a damaged center speaker of you have a damaged center amplifier. You can confirm by first turning down the volume to normal levels and disconnect any one of the speakers and connect it to the center channel output. If you can hear the dialog the center speaker is defective.
Another way to hear the dialog is to change the surround setting to PL II music or just disable surround and chose Stereo mode.
Mar 28, 2011 | Samsung HT-Z320T Theater System
We can't hear spoken audio on our recent dvds (movies), only the music. Some of the the older movies are fine.
Your center channel speaker is not working. In modern 5.1 movies dialogue only comes from the center channel. Older movies were stereo/mono so the dialogue would come from both the front speakers.
See if the speaker wires are intact and not loose. After that to confirm if the speaker is OK or defective exchange the center speaker with one of the working ones.If the center speaker does not produce sound, you will have to replace it. But if it works, that would mean that your center channel amplifier is not working & for that you will need professional help.
CHECK CABLES FIRST FOR LOOSE CONTACTS.
Mar 12, 2011 | Samsung Audio Players & Recorders
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Center/subwoofer speaker out...mixed
Hi all, I also purchased a logitech x-540 a few days ago and also have the center speaker outputting sound when i test or play the subwoofer. I didn't think this is normal and am now confused. Maybe its a problem with the audio drivers? MB is a ASUS P6T Deluxe V2 with Soundmax drivers. Hopefully someone can help to diagnose/ find a soluytion.
Jun 27, 2009 | Logitech X-540 Computer Speakers
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Yamaha RX-V595A Receiver Logo
166 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
