Question about Kitchen Ranges
Stove stop pilot light sparking flame with noise. all i did was clean the stove with an oven cleaner. serial number is sf330peww9 and the mnaufacturer number is p11 431 09nw
  • 1 more comment
  • Anonymous Jul 20, 2008
    the pilot is not light , where do you light ??
  • Samwise10 Sep 20, 2008
    We are having the same problem. My wife was cleaning the stove and and the ignitors keep on going off (making clicking noise). When I turn the knobs I can still get each burner to light. The best solution I could find was from fixitnow.com which suggested: "Do the burners spark continuously no matter which burner is turned on? If so, replace the spark module." I may try that if I can find one, otherwise has anyone else found a solution to this? Thanks
  • Anonymous Feb 18, 2009
    I have the same issue. Cleaned my stopve top and it won't stop clicking. AHHHHHHHHHHHHHHHHHH! Driving me nuts
We ended up unplugging the stove and waiting a day or two while everything dried out and now it is working fine again.
Posted on Sep 21, 2008
Can light the oven pilot light but it won't stay on when I turn the dial to oven temperature. I cleaned the oven prior to this problem with spray on oven cleaner.
I have a 2003 maytag performa stove and i turn the oven on but sometimes it takes a while to come on and smells like gas so and lately i cant get the flames going. i see that the pilot glows but still know flame coming from tubes.
Sep 27, 2010 | Ovens
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Wolf oven won't light after only 3 years since last repair.
You could try a new thermocouple and/or cleaning the pilot assembly. The thermocouple is the tube that screws into the pilot safety valve and runs to the actual pilot and is heated by the pilot flame. If you change this part be sure not to over tighten the thermocouple into the safety valve as it can break. You should go finger tight plus a quarter turn. Also you should check to see if the pilot is solid, not weak. Thermocouples can be purchased from your local equipment service company, sometimes Home Depot has them for water heaters, be sure you get on with proper length. Hope this helps.
Apr 29, 2009 | Wolf Range Challenger CHR-6-1829-FT22...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
My oven
I have found that the pilot will get fouled with a light colored powder due to inpurities in the gas. I usually clean with a tooth brush and pipe cleaner (when cool - no pilot). Otherwise the thermocouple may need to be changed, or at lease re-adjusted to be nearer to the pilot flame. Cleaning every year is prudent.
Apr 21, 2008 | Ovens
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Kitchen Ranges Logo
1,012 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
