Question about Refrigerators
Hi, my refrigerator has stop cooling and there is a flashing light on the panel and non of the buttons are responding when I try to set the temp.
  • hysha42 Oct 02, 2010
    the model #rs2577rs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Eek, it's a Samsung. I'm not a pro at Samsung as of yet so I'm going to bow out of this fix.
Rich
Posted on Oct 03, 2010
    Mentor:
  • 44 Answers
This sounds like a bad control board. What model?
Posted on Oct 02, 2010
    model RS2577RS
Open door 18 beeps lights flash red green fridge not cooling
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 14, 2015 | Refrigerators
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
My refrigerator/freezer is warm
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
Apr 28, 2017 | GE Profile PSW26P Stainless Steel Side by...
Lights Out and Door Open Indicator Flashes
The problem is above the doors at the switch, the unit can't see the switch opening (closing the door opens the switch). The linkage is where the problem is, the light go out to protect the fridge from getting too warm and the lights are remaining on after you close the door.
I hope this helped. Good Luck
Dec 22, 2013 | KitchenAid Refrigerators
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Can you tell me what a flashing # 4 means on the fresh food display,when I try to set temp.the flashing # 4 keeps coming back. the fridge temp. is too cold and freezes everything.
Hello Bryce,
I found a manual, although I cannot be sure it is for your exact model, it is located HERE. This is what is stated under "Temperature Adjustment"
IF TEMPERATURE DISPLAYS FLASH... If ever you see both temperature displays continously flashing, it may indicate that the control system has detected a performance problem. Call your service representative, who can interpret the flashing message. To maintain temperatures, a fan circulates air in the refrigerator and freezer compartments. For good circulation, do not block cold air vents with food items.
This is located under "Turning the Cooling System On and Off"
TURNING THE COOLING SYSTEM ON AND OFF You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and hold it for three seconds. Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops. To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds.
If the manual I selected is not the one for your particular machine, there are others located HERE. There are various ones only differing by a "upgrade" letter on the end, perhaps for different models of different manufacturers, produced by the same company.
I hope this is of some help
Joe
Sep 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
May 16, 2017 | Samsung RS265LBBP Side by Side...
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
