Question about Hotpoint 23 in. BF41 Built-in Dishwasher
Hotpoint, intergrated dishwasher BF12/47916/7 has stopped working, There is nothing happening at all. it has done half a cycle the only thing that happens is when you put the cycle on the dot before cycle no: 2 the power light comes on orange, this usually goes red when the cycle is on. I have changed the fuse & there is no difference. Help!
Poohs
  • 4 Answers
SOURCE: BF162 Hotpoint intergrated dishwasher
When you switch it on can you still select the wash type ?
If you can, when you shut the door does it start the cycle normally by pumping out the sump, but then when the wash pump (the cause of the main noise during the cycle) would normally start it stops and beeps - opening the door then shows the flashing error code ?
If your symptoms are the same as above or similar, suspect the heater is stuffed. My BFI62 did the above and it turned out to be a faulty (open circuit) heater. As I had no knowledge of dishwashers at the time, I called in a repair guy. As soon as he saw the fault code he suspected the heater - seems a batch of heaters (from the USA) had proved very unreliable (apparently Hotpoint got compensation from the manufacturers because of the number of problems it caused them). The replacement was made in Germany and the repair guy said he'd not known one of those to go faulty !
The repair guy diagnosed the heater open circuit from the control panel inside the door without even removing the dishwasher from it's location. Unfortunately, I didn't have a chance to note which wires ran off the board to the heater. Changing the heater needed it out and on it's side (be prepared for quite a lot of water on the floor).
Finally, when he'd fitted the new heater, it took him two goes to get the pipes either side of it to seal properly - quite common apparently and the source of even more water on the floor !
Hope this helps.
Posted on Jan 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: dishwasher trips the fusebox.
You have a obvious short circuit.
Remove the lower panel and inspect the drain valve solenoid attached to the pump beside the motor.
These GE solenoids will stick and melt causing a short circuit.
If not that, open the front panel and inspect all wires for a break.
Posted on May 26, 2009
SOURCE: dwf50 hotpoint aquarius dishwasher
hi, just found this forum after searching the web 4 a solution to my hotpoint DWF50 problem.
I came down this morning to a machine which base tray was full of water and lights 3 ECO & 4 Fast flashing.
Anyway my solution was as i had seen a hotpoint engineer do once before was to press the start/reset button trip the catch, to fool the machine into thinking the door is closed then put in a program, press start, the machine hums slightly but doesnt do anything then after removing the large filter from the tray at the bottom underneath the lower basket insert a length of wire, with a loop on the end (Tip i used a wire coat hanger from the dry cleaners) poke in ythe hole that the dirty water drains from, after a bit of poking about the pump started working and the water drained away. Tip place a hook at the other end of your wire impliment to put your finger in to stop the wire getting caught in the pump mechanisim. After wards u have to hook back the door catch to the normal position, Tip another piece of the coat hanger with a right angled piece at the end will do this. This worked for me, saved me some money esp as D & G insurance ran out 2 weeks ago.....stu
Posted on Jun 22, 2009
SOURCE: Hotpoint Aquarius SDW60 Dishwasher
i have had this dishwasher sdw60 for 18 months and it just keeps beeping, i have cleaned it ,turned it off at the mains it just dont wont to work. please help.
Posted on Feb 08, 2010
SOURCE: My hotpoint Aquarius Dishwasher starts up bu only
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Posted on Aug 21, 2010
Hotpoint 7844 very slow to fill. Takes half hour after initial pump out before it starts. Water just trickles in very slowly, with the solenoid valve humming faintly the whole time. But works fine...
THATS CALLED A IWMS INTERGRATED WATER MANGEMENT SYSTEM :)) SAY THAT AFTER A FEW :))) YES IF ITS GOT LOTS OF BLACK MARKS CHANGE OF CLEAN IT ... ITS VERY HARD TO CLEAN AS ITS MOULDED TOGETHER ... IF IT LOOKS CLEAN CHANGE YOUR FILLING VALVE.
Feb 27, 2011 | Hotpoint Dishwashers
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Opened lid during wash cycle. Machine stopped but later restarted. The same thing happened two weeks later, but the touchpad has no function. It is getting electrical power to the dishwasher. Thoughts?
May 06, 2010 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Hotpoint LFT114 Fully intergrated dishwasher. Hi I've just installed this machine and I find it very noisy compared to our old one. Everything seems to be working OK and dishes come out clean but can't...
Hi! noises can be very elusive, but some more info might give me enough to narrow down your search or figure out if what you are hearing is normal. First, what dishwasher did you have before? The noise that you are hearing, is it during the fill cycle, the wash cycle , drain cycle or just overall noisier than your old one
Nov 05, 2008 | Dishwashers
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Flashing Lights
this error code is time out draining, check for a blockage
Jun 05, 2007 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
