Question about Dell Lattitude D600 Notebook
What causes" ntldr"? - Dell Lattitude D600 Notebook
    Guru:
  • 1,082 Answers
NTLDR fail is either corrupt files or a bad disk drive. Check my tip for how to repair software. If it is a hardware error, don't use the computer and get it to a local shop that can recover your data and replace your disk drive.
My tip: http://www.fixya.com/support/r6101870-windows_xp_failed_start_because_recent
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Posted on Oct 02, 2010
    Guru:
  • 571 Answers
This certain problem is caused by the operating system which uses NTLDR like windows xp and windows 2000. Windows Vista and Windows 7 do not utilize NTLDR.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Generally there are 2 methods to resolve this issue.
Manual File Re-Patching
This method attempts to copy and replace the corrupted file from the Windows Installation disc to your hard disk. To start, follow these steps:
  • Insert the Windows 2000 or Windows XP CD into your computer as default boot up media.
  • Enter Windows Recovery Console
  • At the command prompt, assuming drive D refers to your CD Drive, type in the following and hit Enter:
    Press Y when prompted to overwrite any existing file.
    copy D:\i386\ntldr C:\
    copy D:\i386\ntdetect.com C:\
  • Restart the computer
    If the error message still persist, it is likely that your boot.ini file is corrupted. Try to fix your corrupted boot.ini file instead.
Using Windows Repair Install
This Windows Repair Install overwrites all system files in your computer, leaving your installed applications, data files and settings intact. However, you will lose previously saved system restore points and service pack updates. You may need to re-apply the system updates after this procedure.
Thank you for using fixya.
I hope this helps. Please leave your comments and ratings for your free technical support.
CARLO
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Tip
NTLDR Missing in your Desktop or Laptops PC's
Better if you have a bootable disk to perform this action.(NOTE!)
This tips applicable for all Microsoft Windows Operating System such as XP2,XP3 or Windows 7;, Ultimate,Home and Professional use:
A). Scanning virus on your pc and accidentally or automatically delete your NTLDR system file in your system.B). It will occur when your system unit restarted, and when the system try to boot the specified hardware ex. hard disk where the operating system where stored. this text will appear in your screen("missing NTLDR"). then you cannot proceed to windows. cause the system files cannot boot to it's main purpose.C). NTLDR is main system file for booting up the configuration that's being set in your BIOS system.
on Apr 08, 2010 | Computers & Internet
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
NTLDR is missing is displayed when i turn on the computer
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Mar 01, 2011 | Microsoft Windows XP Professional
NTLDR is missing Press Ctrl Alt Del to restart
The issue is your system is not loading off of the boot drive- check for usb keys, floppies, even sometimes cds can cause the issue. If that does not work, you'll need to get your copy of windows, boot to that disk, and run a chkdsk /r in the repair option. If that does not work, you will need to reinstall Windows.
Oct 17, 2010 | Acer Computers & Internet
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Ntldr is compressed will not boot no more
Dear Friend Most common cause for your question ... some time it happend.. for replaceing Ram...
Some time It happend for.. Delete ntldr file from your C drive...
Some time it happend for Bad Sata or Ide cable,
Same time it happend for Loose connection at Motherboard to IDE device....
First step for you please reinstall the xp i think it will solved. If not please reconnect ide device.. then install Xp if needed.
Best Regards.. sumon
Mar 26, 2009 | Computers & Internet
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Dell Lattitude D600 Notebook Logo
Alun Cox
