Question about HP OfficeJet 6110 All-In-One InkJet Printer
Black cartridge does not put anything on paper colourcartridge prints colour and black and white.fitted new cartridge still the same.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Check expire date on cartridge
if it pass you need to replace them
with fresh one or refill the old ones
If i helped you pls vote me
Posted on Nov 01, 2010
Printer only prints in black/white. have put new
It could be the print setting on your computer.
If you're using Windows, with your document open, go to File > Properties/Preferences. In the Print Setup tab, make sure to select "Print using all available ink" in the Ink Use section.
On Mac you can select Color in Print Setting in any expanded print dialog.
Sep 01, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Black cartridge emptied half way through a four page email.changed cartridge. print appeared to be white...not black. did test print....ok. printed colour photo....ok. printed black and white...
did you try trouble shooting it? Also, make sure your printer header isn't clogged. Clean nozzles. This printer constantly needs maintenance with the channels. Keep them clean, and make sure the ink doesn't dry up. If you use cheap ink the ink tends to dry up fast.
Hunnybunny
Feb 06, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Horizontal line on prints
Put plain paper in the printer and try to clean the nozzles.
-Start->All Programs->Lexmark 5400 Series->Lexmark Solution Center->Maintenance->Clean to fix horizontal streaks.
Steve
Sep 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
PRINTING ON BLACK PAPER
That would require a very special "white ink" print cartridge for your printer. The regular color ink cartridges won't do this, since they can only make the black paper "black-er" when it prints ink on the paper. You may want to ask the manufacturer (Canon) if they make a special "white ink" cartridge for that printer, or know of someone who does. Your only other option is to make a "negative" print image in Photoshop, or a similar graphics software application, and then PRINT the black ink on white paper... which will then leave everything you want to "print white" as an unprinted area on the white surface of regular paper. (Note: with such heavy printing you would want probably want to use a heavier grade of paper, such as 28# or 60#.) This will use a LOT of ink, but it may be the only way you can accomplish your goal. Hope this helps...
Aug 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Printing problem
The black cartridge printhead needs to be cleaned or replaced. Follow your printer manual instructions.
Mar 18, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
