Question about Maytag MER5775Q Electric Kitchen Range
I pressed the cleaning button on my oven now f1 is displayed and the door wont unlock. help!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Your lock motor or lock motor switch is probably defective. Remove large back panel and look for motor/switch with long rod attached.
Rich
Appliance Repair Meridian
Western Appliance Repair
Posted on Oct 02, 2010
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
Sep 03, 2008 | Whirlpool Kitchen Ranges
Oven wont work everytime we push bake E1 and F1 appear
Aug 24, 2008 | Whirlpool Kitchen Ranges
Kenmore locked
The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a try..Catriver...post back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Maytag MER5775Q Electric Kitchen Range Logo
63 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
