Question about Alert Works Enhance Living Series WS20 Deluxe Weather Forecaster
Enhanced living weather station Model WS 20 will not work properly, none of the buttons on the sides are working (so cannot set the time, ect) and the temp from the outside device will not register.
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
How do you set the time?
Page 2 of the manual (linked below) details setting time on this device.
http://www.lacrossetechnology.com/9782twc/manual.pdf
Mar 12, 2015 | Lacrosse The Weather Channel WS-9782TWC-IT...
Change from 24 hrs to 12 hrs
Instructions
    • 1
      Press the "Power" button to turn the machine on. The device takes approximately 5 to 10 seconds to fully load.
    • 2 Press the "Time" button and hold it down for 8 seconds to begin the setting process for the time. Use the arrows on the left side of the device to select the proper hour and minutes. Use the "Up" button to increase the numbers and use the "Down" button to decrease them.
    • 3 Use the arrows to select the time zone that you are currently in. The device automatically adjusts for daylight savings time. Press the "History" button on the right side of the device to view information regarding past weather history.
Read more : http://www.ehow.com/how_7571640_sharp-wireless-weather-station-instructions.html
Nov 02, 2014 | Sharp Weather Station Atomic Clock
Can't shut off alarm totally. It goes off every day. How do I shut it off.
Push the "alm/date" button to display the date instead of the alarm time. If the date is displayed on the LCD, the alarm will not sound.
Jan 06, 2014 | La Crosse WS 9037U IT CBP Wireless Weather...
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
The main unit will not connect with the remote. I have tryed everything that the manual has said to do.. But it just won't work.. They seem to be working but not comunicating with each other..
The WS20 has very poor engineering.
1. Open battery compartments of all remotes and the base unit.
2. The following steps must be completed within a small time window of a minute or two.
3. Remove and replace one battery from the base (reset button on base may also work)
4. Remove and replace one battery on first remote.
5. You have 10 seconds to set the channel number, suggest you set channel 2 first if you have 2 remotes. Once you stop setting the channel on the remote, 10 seconds later remote 2 should sync with the base.
6. Remove and replace one battery on second remote.
7. You have 10 seconds to set the channel number, if you have only two remotes do nothing and it should synchronize 10 seconds after you replaced the battery as remote number 1.
8. If the base unit can receive the time signal from Colorado USA, it should eventually get the time and date correct, give it time. Alternatively you can set the time and date manually. However, if the base is trying to get the time signal, most of the controls freeze up, to unfreeze them press and hold the + button for something like 5 to 10 seconds, then the unit should be available for manual setup.
If you loose connection to one remote or change batteries, repeat all of the above.
In summary, it a POS unit .... :)
Dec 27, 2010 | Alert Works Enhance Living Series WS20...
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Alert Works Enhance Living Series WS20 Deluxe Weather Forecaster Logo
224 people viewed this question
Top Alert Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Alert Measuring Tool and Sensor Expert? Answer questions, earn points and help others
