I have an older (1990's)Optimus CD 100 Professional disc player, and the CD is stuck in the player and wont let me eject the 25 unit holder. The internal play light is blinking as if it is playing the CD. Is there a release button I can press?
  • 9 Answers
SOURCE: Blinking "disc" error
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Posted on Nov 01, 2006
SOURCE: My CD player keeps flashing (F15) when I try to play a disc.
It means that the laser/motor module is disconnected. Open the player and locate the connection band of the module. It should be orange, about 1 cm wide and it comes out from under it. Push it HARD into it\'s socket. Make sure you don\'t leave sweat or grease on the electronic and test it. I hope it works for you!
Posted on Dec 05, 2006
simplemitch
  • 752 Answers
SOURCE: CD Player not playing any audio CDs
The laser is damaged or dirty. Try gently swabbing the lens with rubbing alcohol and drying with canned air. If this fails the laser is damaged and unrepairable.
Posted on Sep 12, 2007
  • 4234 Answers
SOURCE: onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
Posted on May 07, 2008
SOURCE: cd stuck in player
I realize this post is a little old , but for anyone looking for a solution try disconnecting your negative battery terminal for a minute or so then reconnect. Next try to eject your cd. Worked for me ^^
2001 taurus
Posted on May 24, 2008
I have an 1990 JVC XL-M303BK Home Compact-Disc player (2 channel) and am unable to eject the 5-disc cartridge. Is there a solution for this ?
There is a CD jammed in transit between the playing mechanism and the magazine. Some disassembly will be necessary to get the disc into the magazine so it can be removed.
May 28, 2017 | Audio Players & Recorders
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
Cd wont eject out of t_v
Disc loading mechanism fault. Contact any service technician. The mechanism should take out from the TV; either for repair, or replacement. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 21, 2014 | Televison & Video
Pioneer cd player pdc-q180 wont turn and ejects disc, any advice??
have a look inside to see if any forien objects are in the area.otherwise the unit needs to go to a specialist.internal driver unit could be faulty.
Aug 14, 2014 | Televison & Video
Cds are stuck in player and wont unload
If power still to CD Player & Radio, the disc may just be stuck into unit. If it won't eject, after many tries, you need to get unit seen to by In Car Installer / Repair. If no power to unit, try fuse box,
Jul 21, 2012 | 2000 Mazda MPV
I have a 1997 Ford Explorer purchased new with te
is there a coin holder in front of the changer? if so, there may be a coin lodged inside the changer preventing the carrier mechanism from moving. look on the bottom of the changer to see if a coin might be stuck.
Mar 11, 2010 | Clarion DC625 6-Disc CD Changer
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
Stuck disc in JVC CD player
It wasn't a car cd player, but a component for a stereo.  I took off the case and shook the player until the disc dropped out.  We plan to replace the player, so no further help is needed.  Thank you for getting back to me so quickly.
Jan 11, 2009 | JVC AM FM CD DET FACE CAR STEREO
Onkyo 6 disc cd player onkyo DX-C390
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
81 people viewed this question
 Grubhead
Grubhead
