Question about Sansui Televison & Video
Hello! my sansui TFT750 portable dvd mp3 player is having a problem of vertically half screen display.one half display normally while other part has white abnormal display.
silly girl
  • 513 Answers
SOURCE: sansui picture fault
Usualy a problem with the LCD screen itself, that takes replacing the whole screen to fix. Sorry. Could also be an internal connector that has gone bad. There are tiny transistors on most displays that control whole rows and columns. It sounds like one went bad, causing a dead, or constant on, column. Unless you are REALLY handy, it will probably need to go to a service center for repair, which could be very expensive. Try flexing your screen - wrap a non-fibrous cloth around your hand and squeeze the screen lightly all around the edge. If you find a point where squeezing the screen makes things better or worse, explore that point further. Squeeze just hard enough to make a white area go light grey or yellow. It's safe to squeeze gently with something fluffy when the computer is turned-on. Could be a cable problem - either the cable is not making a good connection at one end, or the cable itself may have been crushed and one of the lines in it broken. Replacing the cable is far cheaper than replacing the display. Good luck
Posted on May 17, 2006
techman
  • 3130 Answers
SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Posted on Sep 26, 2006
  • 979 Answers
SOURCE: hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Posted on Nov 26, 2007
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Posted on Mar 28, 2008
  • 170 Answers
SOURCE: Insignia NS-7PDVD portable DVD player - no picture
The unit is failing and is not worth repairing. There is either a short in the wiring that leads to the screen, the inverter board os failing, or the decoder is failing. These are all hardware problems.
There are several tests to find where the problem may be, but the average consumer doesn't have the ability or access to parts to fix these issues.
Posted on Apr 17, 2008
My 9" Coby V.ZON TFDVD9109 Swivel Widescreen Portable DVD Player won't charge but will turn on and stay on as long as I have a charger hooked up what can I do about that
Coby TFDVD9109 9-Inch Widescreen TFT Portable DVD ...
www.amazon.com/Coby-TFDVD9109-9...Widescreen...
Amazon.com, Inc.
Rating: 3.6 - ‎52 reviews
Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ... has never been easier with the Coby TFDVD9109 9" Portable DVD Player. .... The DVD player finally stopped working, won't load discs anymore, gives error message. I had a ... I'm currently doing my research for a new a player but likely will end up ...
Coby TFDVD7009 7-Inch Portable DVD/CD/MP3 Player, Black
www.amazon.com/Coby-TFDVD7009...Portable-Play...
Amazon.com, Inc.
Rating: 3.7 - ‎240 reviews
Ac Power Adapter Cord for Coby Dvd Players Tfdvd1029 Tfdvd7009 .... So in my case 5 zone is needed and it worked well. ... There is inconvenience in charging. ... that once you unplug the battery the connection is so cheap that it won't reconnect. .... Sylvania 9-Inch Swivel Screen Portable DVD/CD/MP3 Player with 5 Hour ...Missing: tfdvd9109
Coby Electronics TF-DVD7006 7-Inch Widescreen TFT ...
www.amazon.com/Coby...DVD7006-Widescreen-Port...
Amazon
Jan 10, 2016 | Coby Televison & Video
My dvd has a white screen
this problem you are encountering is common with most portable DVD player's. The problem most at times is coming from the flex or screen inverter. The flex eventually worn out as a result of regular opening and closing of the player.
The screen displaying white is a symptom of bad flex or inverter.
To confirm, insert a disc into the player, press play. You should hear sound coming out of the speaker of the portable player even as it is playing.
Furthermore, connect an AV cord from the portable DVD player to your TV and you will eventually find out that it is going to display on your TV.
Having done the above, and having confirmed that the flex/inverter is that cause of the problem, please get back to me so that I may direct you further on what to do next.
Your sincerely.
Elect_Comp.
May 28, 2011 | Philips PET702 Portable DVD Player
Hi, I've got a Philips PET706 portable DVD player (screen size 7") Recently, the DVD player can only play DVD disc after it is off for at least half a day. When it is turned on, I can see a normal...
Probably aging parts, like an electrolytic capacitor. Or something heats up and breaks a circuit board track, like a power on reset chip. I'm sure it can be fixed, given enough time and money, and a complete schematic diagram.
When it drives you crazy, throw it out and buy a new one.
Apr 06, 2017 | Philips Televison & Video
Half of the screen is static and the other half is normal.
Sorry,this thing is garbage now the LCD disply screen is dead.Not worth the money to placed LCD dispaly screen,will cost about the same as a new unit.
Feb 09, 2011 | Polaroid PDM-0990DS Portable DVD Player
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
May 12, 2009 | Sony Walkman Video NWZ-S618F MP3 Player
Half of screen rolls
This sounds like a leaky electrolytic capacitor in the unit's video circuitry. You will have to take the unit to a qualified technician for repair, because there are no user serviceable parts inside, & the capacitor in question is about the size of a BB.
Jul 19, 2007 | Durabrand PDV-705 Portable DVD Player
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Televison & Video Logo
41 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
