Computers & Internet Logo
Posted on Oct 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blue light on Monitor keeps blinking when starting computer. computer screen doesn't turn on until about 5 - 8 minutes of blinking, then screen turns on . What's up with this ??
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Oct 03, 2010
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5668999
Points
79191
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Monitor goes off and on by itself
Hello bjaykaye,
The problems you are having are an indication of a Power Supply problem. The issue could be in the switching power supply or the High Voltage Power Supply. The shutdown circuit is activating which is allowing the TV to play until it detects an over-current event. When an over-current event happens the shutdown circuit will turn the TV off. I would suggest that you check the Horizontal Output Transistor, the HV Transformer, the Horizontal damper diode, and the capacitors that are in parallel to the damper diode. The important thing is to find the component that is causing the problem. If you do not have a background in electronics I would suggest that you get a qualified electronics technician to look at the set.
Thank you,
Shuttle83
I have a Gateway FPD1976W LCD monitor. I have never had any problems until yesterday. Was playing a game when. Restarted the computer and everything was fine. Turned off the computer overnight. When I...
all monitors worked new ,yours is 2007 made,
and most old ones are dead now, for sure older than 2010
and used 10 hrs a day the CCFL tubes are now DEAD or odd as H3LL.
blinking means sleep mode
is PC on , are PC fans all spinning?
turn on PC first, then after 30second (now) turn on Monitor last
if monitor is ok (PC not)the monitor tells you PC is dead.
so monitor is bad. what's new there? nothings ever.
CCFL are dead.
test and proof is here.
the magic of 1 flash light
https://www.pcdied.com/monitors_and_screens/flash-light-trick.html#flashlighttest
1helpful
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
2helpful
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
4helpful
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
1helpful
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
1helpful
Blue blinking light
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Grand Canyon Tech
Grand Canyon Tech
