Question about Kenmore Dryers
Kennmore 970-c87192-00 allows EXCESSIVE amount of lint past the lint trap despite cleaning trap prior to each load Am concerned about the growing fire hazard!
  • 4,341 Answers
This is a common condition, and just a maintenance problem. Yearly cleaning at minimum.
Posted on Oct 02, 2010
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Lint trap not collecting lint
the lint trap is a thin gauze material and should trap plenty of lint---are you sure its there or in place properly?
Sep 23, 2012 | Estate TEDS840JQ Electric Dryer
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Dec 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Maytag neptune dryer lint problem
HI bob. thanks for your question. look at your lint filter. if its torn replace the screen. its the only way to stop lint . and clean the venting to the outside, thanks the appliance doc. please rate my answer. thanks
Sep 23, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washer/limt trap clogging causing over flowing
Your machine has a trap, i dont understand the trap in the wall. The standpipe in the wall should be free of anything, which allows the free flow of waste water from the machine; to discharge water at a fast rate.
Plug off the wall, locate the trap -front bottom right side of the machine, unscrew, clean out, be prepared for some water. Refit. The pump-out tube into the wall should be at a particular height, about 3 fee from the ground. And dont push the tube too far into the standpipe.
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire dryer
Most appliance stores sell a brush tahts on a 3 foot handle to remove any excessive lint form the lint trap.
Sep 16, 2007 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
349 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
