Question about Sport & Outdoor - Others
Gas gauge on hewescraft boat stopped working. I determined it was bad float in tank. I replaced with new float I had in garage. It appeared to work until I bolted everything down. Now the gauge is dead. If "F" is at 2 o'clock position and "E" is at 10 o'clock position, the needle is hanging at 6 0'clock position is Dead ! Did I fry the gauge ?? Anything will help
  • marliss_gruv Oct 02, 2010
    There is a decent possibility that when I installed the new sending unit in the tank I may have touched posts to the wrong wires. I believe this would probably fry the gauge. How is a good way to check for short in the gauge wiring ?
  • 11,800 Answers
Not likely - it's probable that when you bolted in the float got stuck. Take everything apart and test it again - if the needle still stays there then yes, the gauge spring failed and the unit is dead. Before you replace it check the wiring for shorts, otherwise the new gauge will be fried instantly.
Posted on Oct 02, 2010
  • Azrael SRL Oct 02, 2010
    Just connect it to a battery, thru a fuse of course - it should go straight to the max/F. If it doesn't then it's dead.
1987 Nissan Maximum gas hand doesn't work & transmission is reading full but it leaks sometimes
There are three fixes possible for the gas gauge....but I would have this troubleshot by a garage:
1. The gas gauge itself does not work anymore. It could have just finally "died". Problem is, you cannot replace just the gauge. It has to be the whole instrument cluster. Having a garage shoot power TO the gauge and then shot the gauge itself will let you know if the gauge assembly is bad.
2. The fuel sending unit is bad. This means the wiring to the gas tank fuel pump/sending unit is bad and does not work. The signal is not being sent to the fuel/gas gauge. This means the fuel pump assembly needs replacing.
3. There is a wire problem somewhere between the gas tank and the dash to the fuel gauge.
The transmission leaking but still reading full just means that there is plenty of transmission fluid in the transmission. The drips or spots you are finding are not enough to "read" low enough. Unless you have a HUGE spot of tranny fluid left on the ground, I would just think about a transmission fluid filter change. This way, a new pan gasket will be installed and fresh fluid filled to the proper level will be accomplished on your car.
Sep 02, 2014 | Cars & Trucks
Have a '92 4runner gas gauge has stopped working properly how does the system work?
It could either be a bad circuit board that controls the gas gauge, or the float in the fuel tank that is connected to the fuel pump has a crack in it and is full of gas so it just sits at near its lowest point.
Jan 23, 2014 | 1992 Toyota 4Runner
Gas gauge stopped working
It could be that the float in the tank is stuck (need to remove the gas tank to get to it) or tha the wire from the tank to the gauge is bad, or could simply be a bad fuse. Check your fuses first.
Aug 14, 2013 | GMC Sierra Cars & Trucks
My gas hand floats on my 2002 oldsmobile silhouette
not sure what the hell that means, but if your fuel gauge is moving around then you probably need a new float. It's located inside the gas tank and usually part of the fuel pump. Not an easy job, but possible...
Mar 22, 2010 | 2002 Oldsmobile Silhouette
I have a 2000 Grand Prix SE and car specs say that it has a 68 liter gas tank. I converted that into gallons, and its about 17.8 gallons. when i refueled, the gas pump only said it put in 12 gallons when...
make sure you fuel tank float isn't becoming saturated with gasoline. If the gauge reads full when it is indeed full, you probably don't have a short in the wire that goes to your fuel float sending unit. If that wire is bare and shorts out it will say you tank is empty since it works on resistance open or unplugged the gauge would read full, closed is or going to ground the gauge will read empty. I would think the float might be bad or the float arm got stuck down when you turned a sharp corner. I had one of these cars but I don't remember exactly where the fuel level sending unit is located and if you need to remove the fuel tank to gain access to the sending unit. I hope this helps you
Mar 09, 2010 | 2000 Pontiac Grand Prix
Fuel Gauge Stuck on Full 98 Pontiac Montana
When gauge is pegged at full, usually means a bad ground. Check wires at fuel tank, wiggle around, maybe one came off. The bad news is it is hard to get to without removing the tank. Sometimes you can reach arm in and get to them. Also check body ground at read of van.
Jul 17, 2009 | 1999 Pontiac Montana
98 ford ranger fuel gauge not working
The float on the sending unit could be jammed of your have a short in the harness.
Check the harness first and pay attention to the connections, if there ok then it's the float on the sending unit on the gas tank.
Sorry for the bad news but it make start to work again any time if it is the float.
Good luck, and hope this helps
Apr 12, 2009 | 1998 Ford Ranger SuperCab
2002 honda crv fuel gauge moves really slow.
I had the same problem. My battery was going bad. When I replaced it with a new one, the fuel gauge worked fine.
Mar 15, 2009 | 2002 Honda CR-V
The gas guage on my 2003 toyota sequoia stopped working
I would check the fuse first, and if that isnt bad, there is a float in the gas tank that sends a message to the gauge to how much gas is in the tank
Dec 11, 2008 | 2003 Toyota Sequoia
1966 Ford Mustang Gas Guage not working
Hi, sounds like you have checked everything properly and you have a bad tank sender, current when checked with test lamp should pulsate.I suggest replace fuel tank sender.
Dec 01, 2008 | 1966 Ford Mustang
Sport & Outdoor - Others Logo
85 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
