Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
Where are the two steel wires go going to the carberator,they start at the govenor
I have a 18hp b&s inteck that want idle the govenor goes back and forth
I believe the condition your describing is called "hunting" this sometimes happens when engine has a problem with it's air/fuel mix usually due to a carb problem
id start by cleaning out the fuel tank and filters and then moving on to the carb
Jan 22, 2016 | Cars & Trucks
1970 John Deere 4020 Diesel, Engine speeds up by its self, I goose the throttle and then it will idle down. pretty sure it is a govenor problem. How do I fix this?
spring is broken/stretched out on govenor linkage bar that runs from air damper flag to injector pump and i would expect a 1970 to be needing a new spring about 5 years ago
Dec 12, 2013 | John Deere Steel Chain/farm/tractor/john...
Trcansmission govenor
It is on the transmission, towards the output housing. Normally close to the pan on the side. It should have a round steel cover held on with either a metal clip or a few bolts.
May 31, 2010 | 1999 Dodge Ram
I have an old tecumseh 10 hp eng model vm100. with carb problem
Rigid link to the top hole on govenor arm, spring link to second hole. If engine 'hunts', try the 3rd or 4th hole. Each lower hole will take off a few rpm, but make the engine less prone to 'overshoot' the goverened speed.
If you have not disturbed the govenor arm clamp where it fixes to the shaft that goes into the engine, that should be all you have to do if you have, proceed as follows ;-
Assemble as above. With engine OFF, loosen the govenor clamp. Push the end of the govenor arm so the carb throttle is wide open. Whilst holding it there, rotate the shaft in the same direction as the arm would have rotated it if you hadn't lostened the clamp. Ensure it's rotated as far as possible (this removes ant 'lost' movement in the internal govenor mechanism.). Now tighten the clamp and release everything. Push the speed control to FAST. The throttle should open, and it will requirer about 4 OZ of force on the end of the govenor arm to close the carb throttle. This force will be generated by the govenor when the engine is started
Move the speed conrol to SLOW. Most of the tention should disappear, allowing the throttle to close with very lettle pressure on the govenor arm.
If all this behaves as described, you should be safe to start.
May 11, 2010 | Garden
I had to repair pull cord, in doing so I took the throttle linkage carborator linkages off to get to the pull rope housing. I need schematics to show all the throttle control springs wire hook up to get...
go to sears.com and look up the actual engine number. they have a section for lawn and garden and in there there is a link to their parts lookup and they are very detailed. but you will need a pulse tach to set the govenor back to where it was and if it spun the govenor open too far due to the govenor not being hooked up, it could have came apart inside the motor and you will need to take it to a shop. as far as setting the govenor once you get it all back together, you need to push the throtle wide open and turn the govenor shaft in the same direction then tighten it down. yeah its not hard if you have done it before but if you havent and cant understand what i just said, save your time, and engine and have a shop fix it. and i havent seen a motor in my 9+ years that you had to remove all of that to fix a recoil rope.
Feb 03, 2010 | Craftsman Rear Mount Tiller
Putting the carberator back together.
one end to the govenor other end to the throttle on carb
Jun 30, 2009 | Craftsman Garden
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Apr 12, 2009 | Watts Onan Portable Generator - 4000 ,...
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
22 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
