Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
I have a whirlpool duet model GEW9250PW1 DRYER The display screen wont light up and there is power going to the unit I can hit the security lock and that indicator light comes on but that is the only light. otherwise you would think it had no power and none of the other buttons work. HELP PLEASE
Sounds like the control board is out. If you remove the lower front cover a hex head screw in each corner, there should be a plastic pouch with tech sheets inside run test #1 part number for the board is 8546219
Posted on Nov 17, 2010
What is capacity of my whirlpool duet ggw9250pw1? I don't see the answer identified. thank you
The Whirlpool Duet ggw9250pw1 looks like it has a 7.0 cu. ft. capacity. This is based on two different sources. The first has the GGW9250PW1 in a list of parts for 7.0 cu. ft. capacity Whirlpool dryer models. See http://www.appliancepartspros.com/search.aspx?model=whirlpool%20duet%207%200%20cu%20ft%20super%20capacity%20electric%20dryer .
Similarly, the related electric dryer, GEW9250PW1, is shown as having a 7.0 cu. ft. capacity at AJMadison.com: https://www.ajmadison.com/cgi-bin/ajmadison/GEW9250PW.html .
I hope this helps.
Nov 27, 2017 | Whirlpool Dryers
Control locked light is on? whirlpool duet dryer-mod GEW9250PW1.
Hi
Press and Hold the End of Cycle Signal button for 15 seconds, this will unlock the control. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet dryer is making a high pitched screeching noise. Model gew9250pw1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Whirlpool Dryers
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
I turn the dryer on (Duet GEW9250pw1) and it just says "sensing" but wont start up...
HI. Your unit is equipped with an electrode(moisture sensor). This sensor helps the unit, in conjunction with the thermostats, to dry the contents during the cycle selected. This error is concerning this sensors integrity. It may be covered with lint, in return, preventing it to sense the moisture correctly, or the sensor may be damaged as well. It is locate just behind the Grill on the outlet lint screen door. I recommend to clean this sensor properly. if the unit continues to show the error code(sensing), this will confirm that the sensor is damaged, and it must be replaced in this case.
Oct 29, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer will not start
all the lights are on but when i hit the start button on the dryer it just clicks any idea why this happens
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
1,047 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
