Question about HP J4680 Office Jet All-In-One Printer
J4680 won't print from laptop, laptop sees 4680 and it gives me an error
  • HP Master
  • 4,336 Answers
WEll, you are short of information but I'll take a stab:
the printer needs to be connected to your router, then you need to use the INSTALL program and NOT plug and play or Windows install printer, to have the printer work wirelessly, on each system.
Remove sharing from host computer, which is likely usb wired to the printer.
Posted on Oct 02, 2010
Printers driving me crazy; I have three HP printers and none will print for me now
To Add and set as Defult Printer Go to system Preferences>Print and Scan > "+" symbol on left corner and add the printer.
when you give a command of print there you can see the list of printers and you can select the printer you want to print from.
Oct 29, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
My hp J4680 won't feed envelopes, the envelopes goes part of the way in and then fails to print
Hi
The envelopes are standard in size hence do not use any odd sizes. And also do remember that you make the required alignment and also the feeding directions and positions. If you print in Landscape then the paper is too short for the printer to pick. Hence use Portrait so your printer can sense the presence of the envelope
Jul 16, 2011 | HP J4680 Office Jet All-In-One Printer
My 4680 HP All in One Printer says there is a paper jam and one does not exist. How do I get it to stop so it will print. Prior to this it was not feeding and making a racheting sound
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 15, 2010 | HP J4680 Office Jet All-In-One Printer
I tried to print a document from internet, there is a message on my monitor telling me that J4680 is printing, but the hardware (printer) is not doing anything. I did run the Self-Test and the printer...
go to the printer page right click on the printer icon that shows the name of your printer
and select as default porinter
if there is any docements in the que try and cancel the documents and see if it gets deleted
again select teh printer as online
and go to the properties page and try to print a test page from teh printer and it should print
and if it does not print disconnect and reconnect teh USB cable from the back of the printer
and try again to print a test page from the printer and this should resolved the problem and still if nothing happens let us know the status and we will help you further with the issue .
BEST OF LUCK
thanks
regards
Hamid
Feb 19, 2010 | HP J4680 Office Jet All-In-One Printer
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
My HP J4680 printer/fax machine keeps displaying the error message "Print Cartridge Problem Tri-color". I have taken the cartridges out and put them back in to see if this will work. It did once and I went...
Try this...http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443507&cc=us&lc=en&dlc=en&product=3692888The message you're getting is a little different, but cleaning the cartridges and the contacts inside the printer might help and might explain why it worked when you pulled them out and put them back in once before.
Jun 08, 2009 | HP J4680 Office Jet All-In-One Printer
I have just got a new HP wireless printer, i have vista on my laptop and even though it said installation was complete it says error when i try and print and says printer offline. its a hp j4680
I had a similar problem,and after spending several hours on the phone with an HP tech yesterday, reinstalling the drivers over and over, we ended up manually creating a port with the printers IP address. Under "printers," right click on the 4680. Go to "properties," the "ports." We added a port, and named it the IP address. Then I could print. I STILL CANNOT SCAN, however!
I also have Vista.
Mar 20, 2009 | HP J4680 Office Jet All-In-One Printer
HP J4680 Office Jet All-In-One Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
