Question about Wap Vacuums
Need new motor 60561 - Wap Vacuums
Need to replace the motor on my Hoover Linx, as everything else has been replaced and it is still VERY loud, and a new motor is cheaper than a new vac. What motor do I need to get?
Julie,
You need to find the model number of your vacuum and then you should be able to just Google the model number and find a website where you could order the motor. If you put the model number in, it did not come through with your question.
Jul 27, 2015 | Vacuums
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Miele vacum motor dead
would need more info to really isolate problem but you either need new cord reel, speed control board, or new motor. maybe all three. either way a make and model number would help
Apr 02, 2013 | Miele Vacuums
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
I need a new motor
red star was part of there low end line. not cost effective as miele parts prices are outrageous.
May 06, 2010 | Miele Red Star Bagged Canister Vacuum
Wife sucked up a nickel cleaning daughters car. Vacuum stopped, smoked before she could turn it off. New motor? Is it worth it? How much is a new motor? Thanks in advance. Jim Troup plinc6@hotmail.com
You can buy a new motor HERE and we will install it with no additional charge for you. You would have to pay for motor and shipping to us.
Good luck,
Rocky
Dec 02, 2009 | Kirby G4 Bagged Upright Vacuum
Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Oct 24, 2009 | Dyson DC14 All floors Bagless Upright...
Need to replace motor brushes on Kenmore canister vacuum 116.25914503 - Getting lots of arcing at brush ends. Need tear-down steps to get at the brushes.
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Sep 30, 2009 | Vacuums
Need to replace motor on a Simplicity upright vacuum and need help with the wiring the new motor. New motor is different from old one.
You might not have the right motor. Take the old one with you because it should go right back in as easy it was to remove.
Aug 22, 2009 | Vacuums
Vacuums Logo
76 people viewed this question
Top Wap Vacuums Experts
ray gallant
Mai Lor
Are you a Wap Vacuum Expert? Answer questions, earn points and help others
