Question about Master Heaters B70DT Liquid Fuel Utility
The heater ignites but runs only for about 40 sec. and the reset kicks out
  • 232 Answers
My guess is the reset is bad, esp if the heater runs fine for the 40 seconds. Next guess would be the thermostat, if equipped.
The problem could be as simple as a restricted fuel filter causing a starvation situation
Since the heater is on your bench and not mine you must troubleshoot to find the problem. This might help: http://www.reddyparts.com/SP_tips.htm
Posted on Oct 04, 2010
When it is raining, my car only goes to like 40 mph and stalls out and shakes and i have to pull over to turn it off then i have to wait a few secs and try it again and it usually runs okay after
Something in your ignition system is getting wet. Are all of the wheel well guards in place, the things that keep water kicked up by your tires out of the engine compartment?
Jun 18, 2016 | Cars & Trucks
I have a used B115. I put kerosene in it. Plug it in, it will run about 5 sec then shut off, kicking out the reset button. Push in the reset and it runs for a shorter time and cuts off again. Have checked...
Remove the top of the heater. Watch out for the fan and turn the heater on. Use a flashlight to look for fuel spraying from the nozzle. If it isn't, check the nozzle for blockage and the fuel filter. If fuel is spraying, make sure the igniter is working. The reset kick out because the flame sensor isn't detecting any flame or is dirty.
Jan 15, 2011 | Master Heaters Master B115DT 115,000BTU...
Water heater runs for 40 seconds or so and stops, smell oil oder
Hello STOP!!!!! don't push the reset button any more.You have a ignition/spark problem.You will load the chamber with oil and will cause major problems when it lites off.Replace the ignition TRANSFORMER on the burner.Avalible for (beckett burner) at home depot/lowes.
Sep 20, 2010 | RTO Bock Water Heaters 51E 50 gal 152,000...
Heater makes the three attempts with 30 sec. intervals. Ignites for 10 seconds on each attempt, but will not kick in and run after the initial ignition.
Firstly make sure that the igniter is properly earthed. The ignitor itself detects the flame and if not properly earthed will not give the proper signal to the control unit. Next the burners need to be checked. They need to be properly cleaned of carbon deposits and oxidisation. If this does not cure the problem then do the following
Turn the gas output up to 2.5" wc(water column) Here's how :
To do this remove the slotted brass cap on the right of the gas valve. Adjust the output valve underneath one turn clockwise. Dont go more than this unless you're familiar with working with gas or have a manometer handy to measure output.
Aug 21, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reset button broken . jumped it out. unite runs for about 3 min.
Sounds like the pump vanes assembly sticking.Use light oil and cleanall, filters[-- screens- plug-vanes- ect...ect!
Dec 17, 2009 | Master Heaters B155DST
Maytag gas range
The hot surface igniter is probably bad. Remove the igniter wires and check for continuity.
Apr 06, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Sterling garage heater wont always light.
The flame sensor is dirty - have the unit serviced. Modern furnaces require regular maintenance!
Mar 10, 2009 | Sterling RF30 Natural Gas Garage Heater
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Master Heaters B70DT Liquid Fuel Utility Logo
163 people viewed this question
Top Master Heaters Heating & Cooling Experts
Gil Shultz
Mike Squire
paulcarew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
