Question about Electrolux Dryers
EDC 3250 dryer issues drying clothes on the 90 setting 30 min into drying it started beeping let sit for 30 min and it's still beeping any suggestions?
ranger25
  • 72 Answers
SOURCE: SLOW DRYING WITH MAYTAG DRYER
Have you checked to see if there is an obstruction in the gas valve itself or if the solenoid is worn? If there is, it will not allow as much gas through, therefor making a smaller flame and less heat. If not, check for pinched gas flex lines either before or after the gas valve or leaks in the combustion chamber. Also take out the lint trap, seal it up with cardboard cutout with a hole in it, take an air compressor with a blowout valve on it set at about 200psi, cover your face and blow out the trash out of the internal ventilation system on the dryer. Should work better after all this. Hope this helps.
Posted on Jan 28, 2008
  • 1073 Answers
SOURCE: Sears Kenmore 80 Series Electric Dryer - starts, kicks off in 5 min
sound like a motor problem it does not have a resetable limit if it was over heating then it would blow the limit and it would not heat, or the blower limit if it sences overheating would not allow the machine to run at all
get ready for a new motor, or a new dryer
200 plus to replace the motor
Posted on May 08, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: I have a Kenmore gas
The problem is with the gas assembly coils. They get hot and quit. Then later on they cool off and will work a little bit. Making it an agrevating intermittant problem. These are only 20 bucks and easy to replace:c433b30.jpg
Posted on Dec 22, 2008
  • 3 Answers
SOURCE: LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Posted on Mar 27, 2009
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 20, 2017 | Dryers
Takes long to dry clothes
on your side, it is better you don't touch anything internal in the dryer as you can hurt yourself and spoil the device even more. have a professional take a look at it before you use it any further.
Jun 11, 2010 | Kenmore 62802 Electric Dryer
I bought the fridgedaire dryer in 2005 and it has to run 3 times for ~40 min each to get the clothes dry. At first I thought it was from the # of turns prior to vent access in my apt (3 elbows and 30 ft...
due to the issue you had in your old home this is what id look for,,,,lint is bilt up in your unit remove the filter and use a dryer brush to clean lint as best you can,,,,,,second remove the vent hose from the back of dryer then with vent OFF try a load to dry if it drys in one setting then you have deturmind the dryer is ok but the vent hose is bad,,finally a bad thermostate or broken heater coil may be the issue and wold needservice,,,try the free stuff first thoe and good luckwww.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Jun 08, 2008 | Dryers
Dryers Logo
167 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
