Question about GE Dishwashers
Dishwasher problem Turned on my dishwasher last night, but I had no water in the washer. Can hear it running, just no water. Checked my water line and it seems fine.
Dishwasher does not turn on
Posted on May 26, 2008
WHY DOES THE MOTOR ON MY SAMSUNG DISHWASHER RUN ALL THE TIME AND THE LIGHT ABOVE HEAVY BLINK?
Yes, you've got a leakage error, which means water has leaked down into the base of the dishwasher. The drain pump runs all the time, trying to get all the water out, but the drain pump can't get to the water down in the base. (Those North Korean engineers/designers aren't too bright.) You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water before that drain pump will stop running. But you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Feb 24, 2015 | Samsung Dishwashers
No water goes into dishwasher
Check the water inlet solenoid, it may be sticking/stuck Soak in a bit of WD40 or CRC. and, try a bit of percussive maintenance, IE: give it a "bit of a whack"
Feb 09, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not turn on. Last night I started
You need to measure with a voltmeter for 115 Volts at the electrical box under the washer front. Breakers can fail, yet look ok. This will check the breaker output and all of the wiring in between. There may also be a local circuit breaker that tripped.
Aug 18, 2009 | Dishwashers
Engine is humming but the water does not make it into the dish washer
Replace the water solenoid valve, but try opening it up first, and seeing if there is any build up inside the valve. This is normal in solenoids just remove the obstruction and water should fill.
Apr 27, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Water keeps running
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
Feb 16, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwasher worked fine last night, this morning it is not working
In some supply systems, there is a safety valve ( commonly referred to as a shuttle valve) that has a small ball bearing that blocks the water from flowing if a water line bursts.. This is supposed to be a safety feature to prevent flooding but can be an annoyance if that ball moves and blocks water flow from coming in.
That, or your water inlet valve may be the prime suspects for this problem..
Hope this helps,
Regards,
Rick
Dec 13, 2008 | Bosch Dishwashers
GU2700XTSB Dishwasher not filling
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Oct 26, 2008 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Dishwasher will not fill with water
there are three or 4 possibility's here remove the kick plate make sure the water valve is plugged up make sure the water is turned on make sure the safety float hasn't slipped off the micro switch that's the dome shaped object in the tub the micro switch is underneath next when you first turn it on do you hear the pump motor run check theese and let me know
Feb 17, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Dishwashers Logo
53 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
