Question about Maytag Washing Machines
My Maytag washer m.mtw58701tw0 doesn`t drain or spin and I just replaced the motor with a new one. What could be the problem?
  • 10,865 Answers
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. Please rate my answer as 4 thumbs up. thanks. Joe
Posted on Oct 02, 2010
I have a maytag pav2300 pump will not pump
see this causes:
It spins, but doesn't pump
drain line is clogged, remove some sock with pliers+test the pump for defective propeller, and replace DO NOT REPAIR
It doesn't spin or pump
frozen pump puller +and replace the pump
It pumps, but the water returns
if the drain hose reach more about 4 inches, cut of the excess
if the hose is lower, install air/gap siphon break assembly
see the diagram.
God bless you
Jun 29, 2012 | Maytag PAV2300 Top Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Maytag MHWE450 spins fine at full speed mid-cycle, for instance between wash and rinse, but will not spin after rinse or on "drain and spin" option. There are no error codes. Seems it might be...
Hello K.W. ,
Sad to sad their is no way to reset the control and yes it sounds as if has diagnosed it spot on ...since it spins on the rinse cycle the motor can be ruled out totally as the problem since its up to the control to tell the motor what to do and when to do it so if it spins sometimes and not others it seems to be the control that's not telling it to spin at the end. One thing to check though is that the filter screen perhaps is clogged since i believe it doesn't spin at high speed until after the water has drained and if the filter on the pump is built up w/debris its not going to drain fast enough so while it may not solve it,it may solve it by checking the drain filter. This tip i wrote will show ya how to check the filter on the pump.http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If the filter is relativity clean and doesn't solve the problem the control baord would need to be replaced.
Sep 27, 2011 | Maytag MHWE450W Washer
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
Maytag ensignia top load washer wont spin. sounds like it is trying to but the motor starts smoking and the machine will shuts off
Hello there and thank you for choosing fixya
Here is a basic on how this cycle works then i will tell you what to look at ok
The washer's motor turns one way for wash, the oppose for spin and drain. The spin function is always preceded by a drain cycle to remove all standing water from the tub and basket. When first starting in the spin/drain direction, the transmission is in 'neutral' and the motor only turns the pump. Once a set amount of time has elapsed, the timer will pause the motor long enough for the drive motor to come to a complete stop. When the timer restarts the motor again in the same (clockwise) direction, the transmission 'shifts into gear' and turns the basket. The pump is still turning in the right direction to pump water out to the drain.
So if it not spinning but it is draining
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you
Aug 16, 2011 | Washing Machines
Maytag navigator washer not draining all the water out
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
