Question about Kohler Home
The toilet seems to be leaking from the bottom. The seal was replaced before and it seems to be leaking when the toilet is not in use. There isn't any leaks from any of the connections that are visible and from the tank. What would cause the leakage at the bottom of the toilet when not in use?
    Problem Solver:
  • 12 Answers
When you have a leak at the bottom there are only a couple of options. One, the seal that was replaced wasn't done properly and needs to be replaced. If you didn't have to sit on it to squash it into place the seal was to thin and you need an oversized wax seal. The other option which is very rare is that the tank itself has a crack and is leaking from the bowl. Like I said, this is very rare. One easily overlooked area is where the tank and bowl are connected. There is a seal between the two and can also leak. This leak will be slow and will usually run down the side of the bowl where you can't see it until it ends up on the floor. If you do find this to be the problem, replace that seal and be sure you don't overtighten the mounting bolts.
My suggestion is that you do both at the same time. As long as you have the water shut off and the tank drained, do them both and alleviate all the problems at one time. The extra cost for the seal between the tanks is only a few dollars.
Posted on Oct 04, 2010
Water leak on toilet base can`t see leak?.
Try tighting the bolts on eather side, do not over tightene you can break the toilet. If that does not work you will have too remove the toilet and replace the wax seal
Apr 13, 2015 | Cars & Trucks
Toilte leaks in front have chk the lines and find no leaks. Is it the toilte
If you have found no leaks on the supply line, be sure to check the seal between the tank and the bowl. This is a common source of leaks, especially on older toilets that have seen much use.
Before you do that though, check carefully at the base of toilet to see if its possible any water is appearing from under the toilet. Your toilet sits on a seal, most often made of wax (sometimes rubber) that seals the water and waste from the toilet into the drain pipe. Normally, those seals last many years. Flush the toilet 3-4 times and observe whether any water seeps out under the toilet. Give it a few minutes (4-5) and recheck. If it is leaking, the fix is pretty simple: Shut off the water, disconnect the source water line just so you won't risk breaking it, and remove the 2-4 toilet bolts. Rock the toilet gently and pull straight up until the seal comes loose. The beeswax seals seem to work the best. Scape off as much of the old wax as you can, and set a new one. They are very inexpensive, and sell for around $2-3.00 USD. To reinstall, remove the protective lining (if present) on the wax, place the ring on the toilet, not the flange and carefully place it straight down onto the flange. Try not to make a mistake - line it up carefully. Press down on the toilet's seat area, maybe rocking yourself a little, until you can see the toilet is back in position.
Next, VERY CAREFULLY tighten the toilet's mounting bolts, a bit at a time, until secure. Over-tightening can break porcelain toilets, so be careful.
OK - either that's fixed or you've ruled it out. Next is the tank seal. Unfortunately, the only way to get to it is take the tank off. If its come to that, first go to the hardware store and secure a replacement set containing the tank seal, a new pair of brass bolts, and the bolt seals. Expect to pay around $4-5.00 USD for the set. The job is pretty easy, you use a wide flat-bladed screwdriver to loosen the (usually) brass screws in the bottom of the tank after shutting off the water and while an assistant holds the nuts from the bottom. You COULD do if yourself, but an assistant makes it easier. Carefully lift off the tank, and you'll see the seal. Remove it, and replace it with the new one, being careful to put it in the right direction, as they are usually cone-shaped. Set the tank back on, put the screws back in, using new seals/bolts (just for good luck) and reassemble. BE CAREFUL when tightening the bolts!! You can easily crack the tank if overtightened.
This is a lot of writing, but just to give you an idea, I could probably change a wax ring in 10 minutes, and the tank seal in 15 or so. Best wishes -
Jun 09, 2014 | Electronics - Others
Aqua piston toilet keeps running....
Kohler customer service has provided a free seal (yellow) to replace the original seal (red)on the bottom of the Aqua Piston. The yellow seal is a big improvement over the red seal, but the toilet tank still leaks. I am ready to return the toilet to Home Depot.
Sep 20, 2013 | Kohler Cimarron Comfort Height elongated...
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
Do you recommend 'sealing' the bottom of a toilet with silicone?
no, it will yellow if p gets on it. Use a flexible acrylic caulk, but not an acrylic adhesive because it will make it hard to lift the toilet in the future without damaging the floor.
Sep 24, 2010 | Kohler Home
Toilet leaks into floor and lower level ceiling, no water on bathroom floor.
Either wax ring or sewage pipe is leaking. If you cant open the ceiling from below to look for leak you may have to remove toilet inspect pipe and look to see if it was leaking from wax ring and if it could have gone downstairs without leaking out too. If leak couldn't have come from wax ring the leak must be coming from a pipe in the floor. Find the simplest way to access it to repair it.
Sep 14, 2010 | Toto Round Carusoe Two Piece Toilet, 1.6...
The big black washer between the tank and bottom is deteriorating also the black washers on the bolts that hold the tank to the bottom are coming apart and the tank is leaking
Any hardware stores where plumbing supply is sold including lowes and home depot sell toilet seal kits including toilet to tank seals as well as toilet rebuild kits. Ask for a toilet to tank seal and washers for the bolts which might come with the large seal(check)
1. Close toilet water valve
2. Drain tank or sop with a towel and squeeze into tub until toilet is empty or bail water out with a cup.
3. Remove two tank bolts
4. clean area where old seals were
5. put tank seal on bowl and set tank lining it on top of seal.
6. Install tank bolts with new seals and tighten evenly
7. Don't over tighten or tank will crack. You probably can tighten until tank and toilet touch evenly on both sides.
8. Fill and check for leaks.
Aug 19, 2010 | Jacuzzi Home
I have the bellevue model and it keeps running even when the toilet has been flushed. It continuely seems to need more water and leaks a bit of water all of the time. It is a new toilet!
Your flapper is not sealing at the bottom of the tank. You can either return the toilet, replace the flapper, or try smearing a little vaseline on the underside of the flapper lip where it contacts the tank bottom. The latter may be all it needs to seal a tiny leak.
Dec 03, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
My whip dual flush toilet leaks around the flapper
the flush neck must be pitted or someting, the part that the flapper sits on that needs to be replaced.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
169 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
