Cuisinart DGB-300 Coffee Maker
Problem for Cuisinart DGB-300 Coffee Maker
Coffee basket
By VickiBrown on May 26, 2008
It's stuck. Read the manual. Says to use the finger grips and the handle and lift out. Does not move. Looks like the grinder blade is stuck and won't lift out.
Solution #1
posted on Feb 13, 2009
Not Rated)
gibsonk
Rank: Apprentice
Rating: 0%, 0 votes
Called Cuisinart - they said to remove the basket ( I unplugged and then used pliers to move the blade/shaft up and down until it wiggled loose ) ... use soap and water to remove coffee oil (the real problem) and then pour a little vegetable oil into the female end where the motor engages the grinder blade to lubricate.
Was this helpful?
Yes
No
Popular Solutions for Cuisinart DGB-300 Coffee Maker
Questions and Unsolved Problems for Cuisinart DGB-300 Coffee Maker
Do you recommend Cuisinart DGB-300 Coffee Maker?
Answer
Answer
I am looking for the grinder lid part for the dgb300 coffee maker
Answer
Cuisinart Grind and Brew Coffeemaker DGB-300 wont grind...the grinder wont work...help!
Answer
I have a Cuisinart DGB-300 Grind and Brew Coffeemaker. The automatic grind is not working. I have... (More)
Answer
keeps beeping when I push on button, for awhile I was able to unplug and try again then it would go,... (More)
Answer
During a normal brewing cycle the cleaning function kicks producing a less than satisfactriy pot of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cuisinart DGB-300 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
