I have a rotex underfloor heating system in a flat I have just brought but I have no instructions on how to operate the room RTR4 room thermostats?
3 Suggested Answers
proton77
  • 1183 Answers
SOURCE: Need wiring diagram to include: Underfloor
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Posted on Oct 30, 2008
SOURCE: I have a rehau ct
Please click on the below link to download the REHAU Technical Manual.
http://www.rehau.co.uk/files/8179_REHAU_BA_Controller_864602_UK.pdf
To set the WLCT (Time and Temperature control) for the system please refer to page number 45 (Section 10: CT Set up Guide).
Posted on Jan 26, 2011
I need a new Rehau Thermostat CT for my underfloor heating, the current one is broken. I am located in Leitrim in Ireland.
Give eBay a look, there are several for sell there.
I would ask if they are EU compatible at 50hz. I'm guessing they are since Rehau is a Canadian company but I'd check first.
Sep 16, 2017 | Heating & Cooling
Tip
Underfloor Radiant Heating for Your New Sunroom
You want to add a brand new sunroom onto your existing house. The problem is that you are not sure how to heat it. Electric heating with baseboard heaters will spoil the look that you want from your new room. Hot water baseboard is going to present all types of problems getting hooked in to the existing system and piping it. And, if you have hot air heating system then you will have the problem of getting ductwork to the room. There is another way to heat this room easily and efficiently.
Radiant heating has been one of the most comfortable and efficient ways for heating for many years. The problem has been in the past to find a good heating source for small radiant floors that will be affordable, effective and efficient.
This problem has been solved now, with the availability of small new electric combination heater- circulator units. These units use small electric heating elements together with a small circulator pump to give you a all in one heating source and circulator pump.
Now you just have to lay your tubing in the floor of the room you are adding on to your house. Then you run that tubing into your existing basement or other room in your house. The tubing and the electric are attached to the heating unit. Then, wire a thermostat to the unit, and you are now ready to make heat. This really makes heating a new addition room very inexpensive and easy to do.
The greatest thing about using this type of heating system is that most average do-it-yourself types can do this. All that is needed is a basic knowledge of plumbing and electric.
If you are thinking of building that little add-on and are worried about how you will heat it, think about using radiant floor heat and a small electric heater-circulator to do your project.
on Dec 05, 2009 | Heating & Cooling
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
Home comfort protection plan
Direct Energy knows that maintaining your Texas home is essential to your family's well-being. You can't afford to put off protection until disaster strikes, so we've created protection for your home's electrical, plumbing, and heating and air conditioning systems.
Our home protection plans deliver security by combining preventive and repair services for your home's most fundamental systems, including:
Electrical wiring
Plumbing lines
Priority scheduling with us for all appointments
Surge protection
Heating and cooling systems
Our home protection plans remove the anxiety of unanticipated costs, while our certified technicians are ready to assist you with respectful, professional service and high-quality equipment. Because we view the money you spend on home service improvement as an investment in your home and your comfort, we're committed to helping you make it worthwhile. You can choose from our plans for Heating and Cooling systems, Electrical wiring, and Plumbing lines. Direct Energy's Repair & Maintenance Essentials Plan provides annual features to catch small service issues before they become critical, $500 insurance for every repair job*, emergency customer support any time you need it, service visits with no charges and no deductibles, and so much more.
if you want protect your roof leaks so you can apply EPDM Coatings :
Watch Corporate Video
Jan 20, 2014 | Audio Players & Recorders
Underfloor heating wont stop running
Look for a stuck relay that controls the pump
Dec 30, 2013 | Hunter Mechanical Heat & Cool Thermostat...
I have a rehau ct room thermostat but don't know how it works - the time needs altering. In another room I have a rehau ta and I think the two work together to control the underfloor heating. Can you tell...
Jan 21, 2011 | Heating & Cooling
I am looking for operation instructions for rehau underfloor heating. Its a 4-event clock thermostat and cant find how to set a timer on it!
You can actually set as many events as you require by changing the settings. The manual is terrible for instructions. I figured it out by trial and error. Hold down the tick button (middle) for about 5 seconds then scroll thu all of the times using the up and down buttons to adjust
Nov 28, 2010 | Heating & Cooling
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Back up electric heater required.
A bit late for you probably Steve, but other browsers might be interested...
Micathermics are faster to warm up the room than other resistive heaters, but otherwise they're no more efficient - so it depends whether you feel that the fast warm up is worth the extra money that the micathermic would cost.
If your ceiling is well insulated (including over the wall plates at the top of the internal walls) then the large windows are very likely the reason that your underfloor heating can't get the heat high enough. Have you considered double glazing? 3M have a very cheap, disposable window insulation kit that you could put on for a cold season to see if it's worth putting in some more permanent double glazing (and in fact that kit will probably last 2 or 3 cold seasons if you just leave it up).
The heater power (kW) required to get that extra 2 degC depends on how well the room is insulated. Your best bet would be to find out how much kW your underfloor heating is putting out and how much degC it is warming up the room, then keep the same proportions to work out how much extra kW you need.
Jan 13, 2009 | Soleus HGW-203 Micathermic Infra-Red...
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
