Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Simpletech 250GB not working with my computer
I am having problems with getting my Simpletech 250GB to work with my computer. My OS is Windows ME and I know that I need drivers for it in order to get it to work. I just can't find the drivers to do so.
  • 1 more comment
  • bruna Jul 02, 2008
    Same problem...
    Solutions?
  • Anonymous Mar 25, 2009
    We use the simpletech 250 to store all our photos. I plug the drive into the USB port and it powers up but it is not recognized nothing comes up in the tray and when I explore the drives it is not recognized. If the drive is defective can I get my pictures?
  • Anonymous Mar 25, 2014
    Lost backup disc and need to download to a Windows XP PC
    Problem Solver:
  • 8 Answers
This is the email I sent to & received back from the company re: the same problem I was having with it. You don't need any drivers.
PROBLEM: I have followed directions re: plugging device in, still cannot see device in MY COMPUTER. I have also tried plugging both USB's into computer to no avail. Even tried using it on my laptop, still not showing. My desktop is XP & loaptop is Vista. When I go to remove the dirve, it DOES show as Fujitsu, but I cannot acces the drive or locate it elsewhere. I really want to like this, but will have to return it if this issue is not resolvable.
SOLUTION: You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Regards,
SimpleTech Technical Support
Posted on Jun 05, 2008
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
My simpletech 250gb cannot be recognized by my computer, i use window now but before i use mac, how can i open my files on my simpletech using widowsXP OS?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jul 07, 2012 | SimpleTech new 250gb simpledrive ext hd...
New computer doesn't recognize device
uninstall the drivers for the hard drive then reboot install drivers that came with drive and then plug it in.
Mar 27, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech not reconize by my computer.
hi there,
i will pass on what was given to me for information. if you are still getting power to the drive you can remove the external casing, remove your pc side panel, where you would insert memory and plug the hard drive into the tape inside your pc to see if the pc will recognize the hard drive. if you are not getting any power or platters spinning then it is more serious. i wish you all the best. cherie
Mar 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech portable hard drive 250gb
are you using a power source for the unit, it has to have its own power supply to work. if you have the cable connected for the power and the usb connected to the laptop/pc, go to the windows log and right click on the logo, a menu will pop up. click on device manager on the device manager settings you should see your drive probably with an x on it, click on the drive and go to the update drivers and make sure you're on the internet. and click update drivers, if there is a driver that windows can use it will install the driver if not, then windows will not load a driver. if still not working try this web site Solvusoft Microsoft Gold Certified Company and download the drivers from them. if this still does not work then replace the usb cable as it may be faulty.
Aug 08, 2017 | SimpleTech 250GB USB2.0 7200 RPM External...
No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
Jul 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Describe your SimpleTech 500GB is not a 250GB
You should not have to install and extra drivers for this device as Windows XP should find this device when you plug it in to the USB port. Try plugging it in to another USB port on your computer. Plug another device in to the USB and see if it works.
When you say the plug and play feature does not work, do you mean that Wndows does not see the device or the backup program is not working?
Mar 21, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
406 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
