Question about KitchenAid KGRS807SSS Gas Kitchen Range
We just bought a Kitchenaid Gas Range, KGRS807, and there is an error code on the keypad that says Keypad Disconnected, F2E0.
5 Suggested Answers
SOURCE: Kitchenaid glass top electric range
That error code is for the "open oven sensor". You probably just need a new sensor.
Posted on Jun 07, 2007
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
Thank you!!! I was going CRAZY trying to solve this one. I ran the self-clean last night and when I tried to use the oven tonight, it just kept giving me the ERR message. The manual from Kitchen Aide is useless. Thank you SO VERY MUCH!!!!!
Posted on May 21, 2008
  • 126 Answers
SOURCE: kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Posted on Jan 02, 2009
  • 2468 Answers
SOURCE: KitchenAid Gas Range Model KGRT:
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
Posted on Mar 27, 2011
Model KSGB900ESS error code F2E0. Is there a procedure for removing error
This error on a Kitchenaid range indicates a problem with the keypad communicating with the main control unit. This can be caused by a wiring problem, a faulty keypad or a problem with the main control. The usual solution is to check the wiring and then replace the keypad if the wiring is fine. Replace the main control if the new keypad doesn't solve the issue. Note: some models only sell the keypad and main control unit as a single assembly.
However, you seem to be missing a digit from the end of the model number. See http://www.appliancepartspros.com/search.aspx?model=ksgb900ess to see the two models. Some parts for the KSGB900ESS1 are here: http://www.searspartsdirect.com/model-number/ksgb900ess1/0593/0124250.html . See the cooktop parts list and look at part 3.
I hope this helps.
Apr 18, 2017 | Kitchen Ranges
Error code f2e0 on whirlpool sf362lxss gas range
This is what I found in looking up trouble codes.
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#ixzz3E437fJJh
Sep 22, 2014 | Kitchen Ranges
Oven Will Not Start
The whirlpool code is that a key button is shorted/stuck. Say's to replace keypad.
Dec 28, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Kitchenaid Ykers807ss00 error display f2e0
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 10, 2013 | Kitchen Ranges
F2:E1 ERROR CODE
Hello Cjarboe,
I understand that your range is given you F2:E1 code this code states that the keypad cord is unpluged. If you find that it is plug in and the error code comes up again you will need to replace the keypad. Here are the dirrections to check/replace the keypad.
1. Unplug, shutoff power to the unit
2. Remove the knobs from the top of the control panel
3. Remove the endcaps
4. Unscrew the control panel
5. Locate the serial cable comming out of the keypad do the jiggle and make sure wire is tight on the keypad and control board.
6. Reassable in the revearse
7. Check to see if error code displays again if it does you will need to replace the keypad.
This range has been discontunuied by whirlpool and parts are hard to come by. Here is a link that I have found the keypad for $243.42 at the followign link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=254959&diagram_id=28176301#d28176301
Thank you for choosing FIxYa.com
Justin
Mar 30, 2011 | KitchenAid KGRT607HBS Gas Kitchen Range
Error code FTE1
dsd Sorry to read about your problem, I hope this helps you out.
you have a keypad issue
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | KitchenAid KGRS807SSS Gas Kitchen Range
What does error code F2E0 mean?
Hi
Thanks for using FixYa. Error F2-E0 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 25, 2010 | KitchenAid Kitchen Ranges
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
F2 E0 - KITCHENAID ELECTRIC RANGE
F2-E0 Shorted Keypad Replace Keypad
Note if keypad is replaced and same code ,
replace control.
Feb 16, 2010 | KitchenAid KESA907PSS Electric Kitchen...
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
103 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
