Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini mer6770aw
Range beeps f1-1 and F1-3 .. already replaced upper oven sensor. Suggestions ?
  • Anonymous Jun 18, 2008
    I am also getting F1-1 and f3-1 replaced upper sensor still haveing the problem.
  • 15,935 Answers
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
We have a Maytag Gemini double oven. The lower element in the upper oven is not working. Tried replacing it, but that didn't work. It's getting power and everything. Any suggestions?
You may have a bad oven sensor. If you look in the oven you will see a small probe about the size of a pen that is the oven sensor. Hope this gets yu going in the right direction. Thank you for using Fix ya
Jun 24, 2011 | Maytag MER6751A Electric Kitchen Range
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6770 F1-3 code Serial #12650733ws
F1-3 is the code for the upper oven being over 950 deg F.
If the oven is now cool, then most likely there is a problem with the temp sensor in the upper oven.
You will need to remove the rear panel from the stove and check the resistence of the sensor to know for sure if it is bad. The only other way is to hook a new sensor to the harness and see if doors will unlock then.
Post back if you have any questions.
Nov 26, 2007 | Maytag MER6772 Gemini Electric Kitchen...
F1-2 fault code persists after sensor replaced
Sensor is about 40.00 I would recommend replacing it yourself. Part number is 12001656 google the part number for places to purchase it. If you use maytag you will pay through the nose!! I have payed twice now! Control panel is part number 74006213 that runs about 200.00 to 290.00 that is probably not your problem, you just had another bad sensor installed. Maytag doesnt care, they already got you when you bought it!
Nov 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
315 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
