Question about Sony Handycam DCR-HC20 Mini DV Digital Camcorder
My SONY HANDYCAM DCR-HC26 touch panel is not working n m unable to forward,rewind,play,or do anything...how do i fix this problem..plzz help..its urgent...
  • scott uppstad Mar 09, 2012
    Switch the camera from the 'off' position to the playback 'mode' repeatedly (about 6 - 8 times in a row) and quickly. I had the same exact issue. This fixed it immediately.
    Scholar:
  • 95 Answers
Most likely, the flex cable that runs from your LCD to your main PCboard is bad. The only thing that you can try to do is flip your LCD around and against the camera. See if the touch screen will work then. The camcorder will still need to be repaired by an experienced technician at some point.
Hope this helps.
www.austintelstarservices.com
Posted on Oct 03, 2010
DCR-HC26 Will not play/rewind/forward.Tried 2 identical cameras and cassetes. Nothing works.
Have you ever heard the silly phrase: "If everything else fails, read the User Manual"?
Please look on P. 23 where it says ... or better yet, here's the picture :-)
dcr-hc26-will-not-play-rewind#solution-section-izwbjt2504mgx4k4p1sstn4i-1-0.jpg dcr-hc26-will-not-play-rewind#solution-section-izwbjt2504mgx4k4p1sstn4i-1-2.jpg
Dec 22, 2014 | Sony DCR-HC26 Mini DV Digital Camcorder
My Sony handycam won't allow me to use the touch screen features in play mode. I can't rewind, play or fastforward the tape. It has reached the end of the tape - what now?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Reinsert the tape and check the operation
Try another tape to check whether the issue persists only with particular tape.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: In the above figure, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Dec 18, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
My Sony Handycam DCR-HC26 started giving me C:31:23 error ''Reinsert the cassette'' when I try to record on a new Sony tape. I am however able play back a previously recorded Sony tape.
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Mar 18, 2010 | Sony Video Cameras
My sony DCR-HC26 TOUCH SCREEN NOT WORKING
it's not exactly the same, but this website shows a pretty foolproof way on how to fix it on a different camera.
http://www.agoraquest.com/viewtopic.php?topic=33427&forum=32&start=10&select_page_number=2
i fixed the touchscreen on my hc26 with it on the first try. i put a piece of paper folded a couple times under the ribbon cable connections where it meets the screen (against the plastic frame for the screen, under the blue cable), and put a piece of cardboard against the circuit board to give it more pressure from that side. works like a charm!
Jan 26, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Set time and date of Handycam
hi,
its a ruttin problem you just change the LCD FLAP its easily available ,just change it and find the magic,
Aug 30, 2009 | Sony DCR-HC32E DV Digital Camcorder
Need a manual for a Sony handycam DCR-HC26
here is the manual for ur camera just read and Be a MAster of ur camera
http://www.docs.sony.com/release/DCR-HC26_Instruction_Manual%5B1%5D.pdf
Pls rate me FIXYA fo rhelp
Apr 22, 2009 | Sony Handycam CCD-TRV37 Camcorder
don't expect any help from sony, they are too lazy to take the time, i'll never buy sony again
Aug 20, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC20 Mini DV Digital Camcorder Logo
1,099 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
