Question about Samsung Televison & Video
My TV was working I brought today and turned it off at remote now it wont turn on it flashes 10 times then stops and wont go on
    Genius:
  • 1,622 Answers
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem, Take care......
Posted on Oct 02, 2010
How do I turn my Dynex 40'' LCD TV 1080P on with out the controller?
Have the remote tested----our shop uses a tester--if remote is bad we usually can fix it for 10 dollars or less.
A digital camera with a LCD display can also be used in a dark room--remote pointed at it and buttons pressed---camera display will flash faintly in response.
Failing that try to locate a replacement remote (good luck with this brand).
May 16, 2012 | Televison & Video
Can't find a code for my ATT Uverse remote. Bought the set in China and brought it back to the US.
Hi! Welcome to FixYa!
You can program your AT&T U-Verse remote control using the Automatic Code Finder. This step cycles through all possible codes for the type of TV you are programming until the correct code has been found. Please follow the steps bellow.
  1. Make sure that the TV you want the AT&T U-verse remote control to control is ON.
  2. With your TV on, PRESS AND HOLD DOWN, the TV Mode Key on the remote control. The mode keys are located at the top of the U-verse remote control. While holding down the TV Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  • The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  • Next steps is start the automatic code finder search. Make sure you aim your remote control at your TV. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the TV turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on your TV.
  • When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the TV or DVD does not turn off, then we need the correct 4-digit code of your TV.
Please refer to the image bellow.
Thank you for using FixYa! Keep me posted. :)
Mar 12, 2011 | Televison & Video
My remote control will not work. I changed the batteries; still won't work. I don't know the reason but when Comcast Cable they brought a Comcast remote which controls only changing the channel's. The...
could be a stuck button press all the buttons on the tv a few times so see if it will unstick or take the remote and a camera phone point the remote at the phone camera and press buttons if you see a flash then the remote is working. if no flash then the remote is defective. if all the buttons on the tv work correctly then it may be a IR sensor problem or mainboard communication problem.
Dec 23, 2010 | Televison & Video
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Sep 16, 2010 | Samsung TV Remote Control
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
Remote JER622
There is a way to program the remote without codes...
make sure the tv (or whatever you are programming for) is turned on
press and hold the button for that function (sat, vcr, dvd, tv, etc), the on/off button will light up
continue holding that button down while you press and hold the on/off button. When the light turns off, release both buttons. The light will now stay on.
Press the play button - it will then cycle through 10? codes I think, while the on/off button blinks. When the button stops blinking, if your tv (or whatever) has not turned off, press the play button again to send the next set of codes. When it turns off, press the reverse button (slowly - to find the correct code) until it turns back on, then press the stop button to save the code. If the remote has cycled through all the codes for that kind of device, the next time you press the play button, the on/off button will blink 5 times and the light will go off.
Hope that made a bit of sense...
Feb 10, 2008 | Jensen 143307 Remote Control
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
Henry  Thomas
Henry Thomas
