Question about Sony PlayStation 2 (PS2) Console
Is there anything i can do to fix the silver strap connected to the LED's
The silver tape that connects to the LED's was loose and soon it fell out of the playstation2 is there a way to fix this? (I was fixing it when this happened, the problem that i was trying to fix was the disc read errors, which i did.I did make sure that i took the top off carefully.)
  • 94 Answers
U dont need the tape
Posted on May 26, 2008
Electricity-conducting tape on TV circuit board?
the silver strip is a ground lead,the tv will work fine without it..just make sure the ground screw are tied
Oct 06, 2017 | Televison & Video
LED Driver damaged
Hello Robert Saunders,
From ONLY what you just described... probably not...
But I'll immediately add that I also heard YOU SAY nothing about ESD (electro-static discharge) handling procedures.
If you EVER plan on going inside ANOTHER electronic device
you will greatly improve your chances of success by GETTING, KEEPING and WEARING a ANTI-STATIC-WRIST strap.
Every semi-conductor company (makers, users & repairers) of any CONSEQUENCE all use anti-static PRECAUTIONARY PROCEDURES (or they'll soon be OUT-OF-BUSINESS)...
Those silver tinted or sometimes pink shipping bags
are called FARADAY bags... Grounded anti-static mat (carpets)...
and finally for the HUMAN TOUCH... the ANTI-STATIC-WRIST strap (see below)...
All designed to keep the tiniest spark away from semi-conductors.
Skip all the reading...
Trust me... it is really important (wrist strap)...
One of my favorite talented young TV fixers (blogs a lot)
give informative & inspiring directions on EXACTLY where you are working... (He's one of those "ground your hands" guys...
On one of his "blogs" on youtube
he took out a pack... with a static spark...
Tampatec (fun to watch ... see bottom).
Happy hunting!!
ESD Training Program Protected Areas
TV Parts Universal TV Stands DLP Chips ShopJimmy
Tampatec flat panel lcd Ask com YouTube Search
Jul 28, 2016 | Televison & Video
Visual touch screen is blank for 1900 series embroidery machine
'm not technical so please bare with my terminology. There is an area soldered from the knob to the LCD Screen. Don't make the same mistake I did and turn it so much it breaks completely loose and connection is totally lost == my the knob fell down inside the machine. Sears said it would cost me $400 to fix because they would have to replace the whole LCD Screen. Turn your knob to where you get the best light and try taping it to the top or side of the sewing machine-- then don't touch it. Otherwise it will be costly to get fixed. Good luck
Feb 15, 2015 | Kenmore 19001
Install chandler
The silver metal you refer to is a junction box. If you are installing a standard chandelier, a strap is mounted on the two round ears one of which is shown in your video. There is a hole in the middle of the strap and your chandelier attaches to that hole. With the chandelier suspended from the strap, you now have room to make the wire connections. When finished, the wire connections are pushed up into the junction box and the canopy is tighened to finish the job
Jun 15, 2013 | Home
The display on my Amilo Pro V2030 is black after it fell on the floor. Does this necessarily mean that the display is dead and needs to be replaced or external monitor used? Could the problem be fixed in...
May be a loose connection, at best, at worst, HDD damaged, etc., etc., etc.. Does it boot? Fan spins? LED's Blink? Sound? Anything? If you connect a External Monitor does it work? There are cable at the bottom and rear of the monitor that can come loose.
May 04, 2013 | Fujitsu Siemens Amilo Pro V2030 Laptop...
Washer tub/basket is visibly uneven or unbalanced
Check the rubber damper straps ('cables") by hand to make sure they aren't cracked or broken (a light tug on each should suffice). Sometimes it isn't obvious visually, especially if you don't have good lighting. If one strap is bad, replace the entire set. Also inspect the attachment points for the straps to make sure they aren't loose or bent.
If you are sure the damper straps are good, then check the suspension under the tub for excess wear or breakage.
Jul 25, 2017 | General Electric WJRR4170GWW Top Load...
Connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Mar 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
Canon uc-1 video 8mm camcorder
Yes it can be fixed, but Canon is not the easiest to work on. Is the connector loose at all? The audio head may be dirty. This is not on the spinning heads. If you look inside and locate the pinch roller (rubber roller), there should be a silver head that looks like a cassette tape head. Try cleaning that using a cotton swab and alcohol. See if that resolves the problem.
Keep us posted.
Dan
Jul 23, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Sony PlayStation 2 (PS2) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
