Question about Sony PlayStation 2 (PS2) Console
Red light on playstation will not turn green
THERE IS POWER TO THE PLAYSTATION BUT WHEN YOU PRESS THE POWER BUTTON TO TURN IT ON THE LIGHT STAYS RED AND IT WILL NOT TURN ON!!!!!! PLEASE HELP!!!!!
  • 4 more comments
  • Favfas Jun 10, 2008
    When me and friend were going to play GTA SA the red light did not turn green we also tried unscrewing the PS2. still did not work
  • Anonymous Jan 06, 2009
    same here, the red light comes on but it never turns green.....
  • caguerra79 Jan 15, 2009
    my ps2 shocked my when i touched it. the red light is on but will not go to green, am desperate for help. please inform
  • Raahimfareed Apr 30, 2009
    i have the same problem, i removed Burnout revenge and after that it has the same problem as described by all ....what to do
  • m_e_digital May 03, 2009
    i have the same probelm sure wish some one knew how to fix it we only used it a few times then this happened
  • Anonymous May 15, 2009
    when I'm play around 2 to 3 minutes ,the green light turn to red automatically and games no more playing.I restart but it stay cant used.
    But this problem happen just sometimes.
    1 more,when the green light change to red,some noise sound appear
    inside my ps2,sound like fan is spinning hard...plz...
  • 94 Answers
U might have to use a higher voltage plug
Posted on May 28, 2008
When i turn my PS3 on the light goes from red to green but nothing else happens, the discs load and eject thats it. You cannot turn the system off without turning the power off at the wall.
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the light on the front goes green white red
Send it in for service at a Sony playstation service center.
It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Can't turn on my playstation 3
you have the red light of death its a hardware failure and is almost always the gpu or cpu lifting off the board
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Not turning on
So, ur using the power button in the back, and then the red light turns on? Press the blue and green button on the front, and if that doesn't work, i would save up for an Xbox 360.
Apr 15, 2009 | Sony PlayStation 2 (PS2) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 wont turn on
if there is not even a red light that means that the power supply is gone. find a working one of ebay and install it yourself if your warrantu is expired.
Aug 31, 2008 | Sony Playstation 3 (PS3) Console
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
293 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
